Andre-Pretorius
Joined: 09 Mar 2010 Posts: 9 Location: South Africa, Klerksdorp
PIC18F4550 not starting [solved] |
Posted: Fri Apr 02, 2010 4:42 am |
I am busy converting code from PICBASIC pro to CCS. I have tried to get the serial port working but it seems the chip is not starting up. I have tested the hardware with PicBasic and all hardware is working.
The board has a 20mHz crystal and it needs to run at 48mHz. MCLR is connected to VCC. I assume it is a switch fault - can anyone help?
#include "main.h"
setup_adc_ports(AN0_TO_AN3|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_32);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
while(true)
output_high(PIN_D4);
DELAY_MS (500);
output_low(PIN_D4);
printf("hallo");
DELAY_MS (500);
main.h
#include <18F4550.h>
#device adc=10
#FUSES HSPLL //High Speed Crystal/Resonator with PLL enabled
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES NOICPRT //ICPRT disabled
#use delay(clock=48000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
_________________ Andre Pretorius |
Andre-Pretorius
Posted: Fri Apr 02, 2010 7:37 am |
Ok got the board to start up, my fault was at the extended instructions. Now I have another problem left: I have a 20mHz crystal on the board but my timing is wrong. The delay_ms(500) gives a delay of almost 5 sec.
#device adc=10
#int_RDA
void RDA_isr(void)
setup_adc(ADC_CLOCK_DIV_64);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
while(true)
DELAY_MS (500);
output_low(PIN_D4);
printf("hallo");
DELAY_MS (500);
Andre-Pretorius
Posted: Fri Apr 02, 2010 8:05 am |
Found problem two more switches
#FUSES PLL5
#FUSES CPUDIV1
Is working now _________________ Andre Pretorius |
