Help with 4x3 Keypad, LCD and PIC16F877A
elektronische
PostPosted: Thu Mar 18, 2010 9:02 pm     Reply with quote
I have a problem trying to connect a 4x3 keypad to a LCD using a PIC 16F877A. I can't get the data from the keyboard. Accompanied by the code and diagram on ISIS, maybe you can help me.
#include <16f877a.h>                      //PIC utilizado
#fuses HS,NOWDT,NOPROTECT,NOLVP           //Configuramos los fuses
#use delay (clock=4000000)                //Oscilador a 4Mhz
#INCLUDE "lcd.c"                         //Incluyo LCD.C
#INCLUDE "kbd.c"
void lcd_mostrar(void);
#define use_portb_kbd TRUE
port_b_pullups(TRUE);
kbd_init();
lcd_init();
lcd_mostrar();
char c=0;
while(TRUE){               // Bucle infinito
   do{                     // Espera hasta...
      c=kbd_getc();
   }while(c==0);           //...pulsar una tecla
   lcd_gotoxy(1,1);
   lcd_putc(c);            // Muestra tecla pulsada en lcd
   lcd_putc("\b");
PostPosted: Thu Mar 18, 2010 10:52 pm     Reply with quote
lcd_gotoxy(1,1);
lcd_putc("\b");
That's not the correct way to send a control character with lcd_putc().
You need to use single quotes. Example:
lcd_putc('\b');
elektronische
PostPosted: Sat Mar 20, 2010 6:57 pm     Reply with quote
I did change that, but still doesn't works! any other suggestion? thanks
PostPosted: Sun Mar 21, 2010 1:21 pm     Reply with quote
There is another problem with your code. The #define statement below
in your code, affects all the code that occurs after it. You want
it to affect the kbd.c driver, but it will not, because you put it after the
#include "kbd.c" line.
#INCLUDE "kbd.c"
You need to move it above the #include "kbc.c" line, as shown below:
#INCLUDE "kbd.c"
Then the keypad code will be configured to run on Port B.
elektronische
PostPosted: Sun Mar 21, 2010 1:54 pm     Reply with quote
Finally it works !!
Thanks for the clarification about define the Port B.
saqi
PostPosted: Wed Mar 24, 2010 1:11 am     Reply with quote
I have made the hardware for this coding. It is working on Proteus but
does not work on the hardware. Plz give me some suggestions. I am new
in this. I don't know about coding.
Thank you Smile
PostPosted: Wed Mar 24, 2010 12:56 pm     Reply with quote
The Proteus schematic doesn't show a crystal (with 22 pf capacitors), or
an MCLR pull-up resistor (10K ohms). It doesn't show power and ground
connections (Vdd and Vss) to the PIC. It doesn't show a 100 nF (0.1 uF)
capacitor between each Vdd pin and ground.
All of these things are necessary in the real world.
saqi
PostPosted: Wed Mar 31, 2010 4:33 pm     Reply with quote
still not working Sad i have an idea about the basic circuit of pic but its not working
elektronische
PostPosted: Wed Mar 31, 2010 5:18 pm     Reply with quote
Are you sure that the pins order in the keypad is the correct?
smanzer
Did you try flex_KBD.c?
PostPosted: Mon Apr 05, 2010 7:43 pm     Reply with quote
Just a thought, I use a derivative of the flex_KBD.c for some of my projects.
I have modified it to use a buffer for keys, and call:
Key=kbd_getc(); in the #int_rtcc real time clock interrupt. This gets called 38 times per second and works perfectly.
Originally, I was not calling the kbd_getc() often enough...
Hope you get it going, a keypad with LCD and RS232 terminal make coding/debugging and using it so much nicer.
Cheers!
Steven
"I am always doing that which I can not do, in order that I may learn how to do it."
- Pablo Picasso
