void abc(void)vs void abc()
project2010
PostPosted: Wed Mar 31, 2010 11:48 am     Reply with quote
What is the difference between it?
Also something I see put some data into () like> (int8 data),(float data)
somethime start with int8 data(void)?
What case should I place something into ()?
Thank you
PostPosted: Wed Mar 31, 2010 12:11 pm     Reply with quote
Look in this C reference:
http://h30097.www3.hp.com/docs/base_doc/DOCUMENTATION/V50_HTML/ARH9NATE/DOCU_012.HTM#func_define_sec
Search for this string.
empty parameter list
That section will explain it.
Here is a good tutorial on functions:
http://www.nada.kth.se/kurser/master/intro/Course04-05/Handouts/Flecture05.pdf
wulffert
PostPosted: Sat Apr 03, 2010 11:10 am     Reply with quote
I find it is better to explicitly say what it is. Usually empty brackets on most compiler will generate a warning (no parameters) the linker will just ignore and create a call as if it were void anyway.
http://wulffert.com
http://towerlightmonitor.com
