SED1335 driver (with anti-flicker)
dezso
PostPosted: Sat Mar 27, 2010 12:00 pm     Reply with quote
I got my 1335 up and running, works very good, except for fast screen update, serious flicker affecting the whole screen, not that noticeable but I see it !
I have been searching for a solution. The D6 busy check what included in the sed1335.c is not working for me. As soon as I try to check for busy bit before write, the whole screen stops working.
Found this link last night, http://www.microchip.com/forums/tm.aspx?m=432421, anyone have any input on this flicker problem ?
PostPosted: Sat Mar 27, 2010 10:12 pm     Reply with quote
If you want help, you need to tell people how to duplicate the problem.
Tell us what sed1335 driver you're using. If it's not the CCS driver,
then post a link to it. Also post a small, compilable test program
that uses the driver and demonstrates the problem. The test program
must compile with no errors if we copy and paste it into MPLAB.
Post the absolute minimal test program that shows the problem.
(no excess Wizard code).
Also post your compiler version.
dezso
PostPosted: Sun Mar 28, 2010 7:35 pm     Reply with quote
http://www.youtube.com/watch?v=Sd6eYOah_xI
I'm back to the original SED1335.c found in the drivers directory, the file modified but not changed, I only added new function to it, like my lcd has a built in vee gen ic and have to initialize it first.
The graphic.c also has new functions but not modified.
Note the horizontal white spots flicker on the black area !
I have this problem since day one ! could be the display ?
CCS PCH 4.105,
dezso
PostPosted: Sun Mar 28, 2010 10:04 pm     Reply with quote
Here it is.
Just the basics.
http://www.youtube.com/watch?v=BDIrCUJ_zZw
Main.c
////                           Auarium Controller                    ////
////   Monitor PH,Temp, Salt and controll pumps and lights         ////
////        (C) Copyright non                                               ////
   #include <18F448.h>
   #fuses H4,NOWDT,NOPROTECT,NOLVP
   #pragma use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
   #define LARGE_LCD
   #include <C:\Projects\GLCD_CCS\GlobalVariables.h>
   #include <C:\Projects\GLCD_CCS\STRING.H>
   #include <C:\Projects\GLCD_CCS\SED1335.C>
   #include <C:\Projects\GLCD_CCS\GRAPHICS.C>
   #include <C:\Projects\GLCD_CCS\MATH.H>
//   Main Program
   setup_adc_ports(RA0_ANALOG);
   set_adc_channel(0);
   SET_TRIS_B( 0xff );
   glcd_init(ON);                                  // Must initialize the LCD
   DELAY_MS(500);
  glcd_fillScreenText("#");
   for(;;)
    sprintf(tempc, "Hello DDS");
    glcd_text57(10, 70, tempc, 4,on);
    delay_ms(10);
sed1335.c
////                           SED1335.c                             ////
////  Example drivers for the SED1335 LCD controller on an Ampire    ////
////  AG-320240A1 display.                                           ////
////  glcd_init(mode)                                                ////
////     * Must be called before any other function.                 ////
////       - mode can be ON or OFF to turn the LCD on or off         ////
////  glcd_pixel(x,y,color)                                          ////
////     * Sets the pixel to the given color.                        ////
////       - color can be ON or OFF                                  ////
////  glcd_fillScreen(color)                                         ////
////     * Fills the entire LCD with the given color.                ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#ifndef SED1335
#define SED1335
#ifndef GLCD_WIDTH
#define GLCD_WIDTH         224
#ifndef GLCD_HEIGHT
#define GLCD_HEIGHT        240
#ifndef GLCD_CHAR_WIDTH
#define GLCD_CHAR_WIDTH    8
#ifndef GLCD_CHAR_HEIGHT
#define GLCD_CHAR_HEIGHT   8
#ifndef GLCD_RST
#define GLCD_RST           PIN_C4
#ifndef GLCD_RD
#define GLCD_RD            PIN_C2
#ifndef GLCD_WR
#define GLCD_WR            PIN_C1
#ifndef GLCD_CS
#define GLCD_CS            PIN_C3
#ifndef GLCD_A0
#define GLCD_A0            PIN_C0
#ifndef ON
#define ON                 1
#ifndef OFF
#define OFF                0
// The following defines setup the memory used by different regions
// Currenty one text area is defined at the beginning of memory
// and a graphics area follows immediately after
#define GLCD_TEXT_ADDR              0x0000
#define GLCD_GRAPHICS_ADDR          GLCD_WIDTH * GLCD_HEIGHT / 64
#define GLCD_GRAPHICS_ADDR_END      GLCD_GRAPHICS_ADDR + (GLCD_WIDTH * GLCD_HEIGHT / 8)
#define   Max_749_ADJ      PIN_A5
#define   Max_749_CNTRl   PIN_E0
#if GLCD_CHAR_WIDTH < 9
   #define GLCD_CR (GLCD_WIDTH/8 - 1)
#else
   #define GLCD_CR (GLCD_WIDTH/4 - 2)
//#define set_command();   output_high(GLCD_A0): status_d = 1;
//#define set_data();      output_low(GLCD_A0): status_d = 0;
int8 glcd_readByte();
void glcd_sendByte(int8 data);
void glcd_fillScreen(int1 color);
void glcd_fillScreenText(char c);
void setCursorAddress(int16 addr);
void glcd_pixel(int16 x, int16 y, int1 color);
int8 getData(int16 addr);
void glcd_sendCMD(int8 cmd);
int8 getStatus();
void glcd_systemSetup();
void glcd_scrollSetup();
void glcd_overlaySetup();
void glcd_power(int1 mode);
void glcd_cursorDirection(int8 dir);
void glcd_cursorForm(int8 width, int8 height);
void setData(int16 addr, int8 data);
int status_d;
#define GLCD_CMD_SYSTEM          0x40  // General system settings
#define GLCD_CMD_SLEEP           0x53  // Enter into standy mode
#define GLCD_CMD_DISP_OFF        0x58  // Turn the display off
#define GLCD_CMD_DISP_ON         0x59  // Turn the display on
#define GLCD_CMD_SCROLL          0x44  // Setup text and graphics address regions
#define GLCD_CMD_CSR_FORM        0x5D  // Set cursor size
#define GLCD_CMD_CSRDIR_RIGHT    0x4C  // Cursor moves right after write to display memory
#define GLCD_CMD_CSRDIR_LEFT     0x4D  // Cursor moves left after write to display memory
#define GLCD_CMD_CSRDIR_UP       0x4E  // Cursor moves up after write to display memory
#define GLCD_CMD_CSRDIR_DN       0x4F  // Cursor moves down after write to display memory
#define GLCD_CMD_CGRAM_ADDR      0x5C  // Configure character generator RAM address
#define GLCD_CMD_HDOT_SCR        0x5A  // Set horizontal scroll rate
#define GLCD_CMD_OVERLAY         0x5B  // Configure how layers overlay
#define GLCD_CMD_SET_CSR_ADDR    0x46  // Set the cursor address
#define GLCD_CMD_GET_CSR_ADDR    0x47  // Read the cursor address
#define GLCD_CMD_DISPLAY_WRITE   0x42  // Write to display memory
#define GLCD_CMD_DISPLAY_READ    0x43  // Read from display memory
void set_command()
    output_high(GLCD_A0);
    status_d = 1;
void set_data()
    output_low(GLCD_A0);
    status_d = 0;
// Purpose:    Set the MAX749 LCD voltage generator contrast voltage
// Inputs:     The byte of data to write
void glcd_contrast(byte contrast)
{   //byte   contrast;
   set_tris_b(0x00);
   output_low(Max_749_ADJ);
   delay_cycles(10);
   output_low(Max_749_CNTRL);
   delay_cycles(10);
   delay_cycles(10);
   output_high(Max_749_ADJ);
   delay_cycles(10);
   output_high(Max_749_CNTRL);
   do   {
         delay_cycles(4);
   while(contrast--);
// Purpose:       Initialize the controller
// Inputs:        The initialization mode
//                OFF - Turns the LCD off
//                ON  - Turns the LCD on
void glcd_init(int1 mode)
   // Initialze some pins
   output_high(GLCD_RST);
   output_high(GLCD_CS);
   output_high(GLCD_RD);
   output_high(GLCD_WR);
   glcd_systemSetup();
   glcd_scrollSetup();
   glcd_power(OFF);
   glcd_cursorForm(4, 6);
   glcd_fillScreen(OFF);
   glcd_fillScreenText(' ');
   glcd_power(mode);
   glcd_cursorDirection(GLCD_CMD_CSRDIR_RIGHT);
// Purpose:       Turn a pixel on a graphic LCD on or off
// Inputs:        x - the x coordinate of the pixel
//                y - the y coordinate of the pixel
//                color - ON or OFF
   int8  data;
   int16 addr;
   // Calculate the byte address containing the pixel
   addr = GLCD_GRAPHICS_ADDR + (GLCD_WIDTH/8 * y + x/8);
   // Read the byte of data at the address
   data = getData(addr);
   // Turn the pixel on or off
   if(color == ON)
      bit_set(data, 7 - x%8);
      bit_clear(data, 7 - x%8);
   // Write the new data byte to display memory
   setData(addr, data);
// Purpose:    Initialize the display environment
   output_low(GLCD_CS);
   glcd_contrast(2);
   glcd_sendCMD(GLCD_CMD_SYSTEM);          // Setup the system
   set_data();                             // Set for data
   glcd_sendByte(0x30);                    // No offset
   glcd_sendByte(0x7F + GLCD_CHAR_WIDTH);  // Set character width
   glcd_sendByte(GLCD_CHAR_HEIGHT - 1);    // Set character height
   glcd_sendByte(GLCD_CR);                 // Display line address range
   glcd_sendByte(0x2F);                    // TC/R
   glcd_sendByte(GLCD_HEIGHT - 1);         // Number of lines per frame
   glcd_sendByte(GLCD_CR + 1);             // Horizontal address range LSB (APL)
   glcd_sendByte((GLCD_CR + 1) / 0xFF);    // Horizontal address range MSB (APH)
// Purpose:    Set the scroll start address and
//             the size of a scroll block
   // Currently setup for a text and graphics layer
   glcd_sendCMD(GLCD_CMD_SCROLL);              // Setup scrolling
   glcd_sendByte(GLCD_TEXT_ADDR);              // SAD1L
   glcd_sendByte(GLCD_TEXT_ADDR / 0xFF);       // SAD1H
   glcd_sendByte(GLCD_HEIGHT - 1);             // SL1
   glcd_sendByte(GLCD_GRAPHICS_ADDR);          // SAD2L
   glcd_sendByte(GLCD_GRAPHICS_ADDR / 0xFF);   // SAD2H
   glcd_sendByte(GLCD_HEIGHT - 1);             // SL2
   glcd_sendByte(0x00);                        // SAD3L
   glcd_sendByte(0x00);                        // SAD3H
   glcd_sendByte(0x00);                        // SAD4L
   glcd_sendByte(0x00);                        // SAD4H
   glcd_sendCMD(GLCD_CMD_HDOT_SCR);            // Horizontal scroll rate
   glcd_sendByte(0x00);                        // Horizontal pixel shift is 0
// Purpose:    Setup the overlay functionality for combining
//             layers of text and graphics, or multiple
//             graphics layers
   // Currently setup for a single graphics layer
   glcd_sendCMD(GLCD_CMD_OVERLAY);              // Text / graphic overlay mode
   glcd_sendByte(0x8);                         // Area 1 text, others graphics
                                                // Text XOR Graphics
// Purpose:    Turn the display on or off
// Inputs:     ON to turn on or OFF to turn off
   if(mode == ON)
      glcd_sendCMD(GLCD_CMD_DISP_ON);           // Turn the display on
      glcd_sendCMD(GLCD_CMD_DISP_OFF);          // Turn the display off
   glcd_sendByte(0x14);
// Purpose:    Set the direction the cursor moves after
//             writing to dispaly memory
// Inputs:     Use one of the following to set the direction:
//             GLCD_CMD_CSRDIR_RIGHT
//             GLCD_CMD_CSRDIR_LEFT
//             GLCD_CMD_CSRDIR_UP
//             GLCD_CMD_CSRDIR_DOWN
   glcd_sendCMD(dir);
// Purpose:    Set the size of the cursor
// Inputs:     1) The width in pixels - 1  Valid numbers: (0 - 15)
//             2) The height in pixels - 1 Valid numbers: (1 - 15)
   glcd_sendCMD(GLCD_CMD_CSR_FORM);             // Cursor form and size
   glcd_sendByte(width);
   glcd_sendByte(0x80 + height);
// Purpose:    Fill a graphics layer passed in color
//             Works much faster than drawing a rectangle to fill the screen
// Inputs:     ON - turn all the pixels on
//             OFF - turn all the pixels off
   int16 i;
   setCursorAddress(GLCD_GRAPHICS_ADDR);
   glcd_sendCMD(GLCD_CMD_DISPLAY_WRITE);
   set_data();
   for(i = GLCD_GRAPHICS_ADDR; i < GLCD_GRAPHICS_ADDR_END; ++i)
      glcd_sendByte(0xFF * color);
// Purpose:    Fill a text layer with a the passed in character
   int16 i;
   setCursorAddress(GLCD_TEXT_ADDR);
   set_data();
   for(i = GLCD_TEXT_ADDR; i < GLCD_GRAPHICS_ADDR; ++i)
      glcd_sendByte(c);
// Purpose:    Get the status
// Outputs:    The status in an 8 bit integer
int8 getStatus()
   int8 status;
   set_data();
   output_low(GLCD_RD);
//   delay_us(1);
   status = input_d();
   return status;
// Purpose:    Write a byte of data
void glcd_sendByte(byte data)
   output_d((data));
 //  delay_cycles(1);
   output_low(GLCD_WR);
// Purpose:    Read a byte of data
// Outputs:    The byte of data
   byte data;
   set_tris_d(0xFF);
   //delay_cycles(1);
   //delay_cycles(2);
   data = input_d();
   return data;
// Purpose:    Get the current address of the cursor
// Outputs:    A 16 bit integer containing the cursor address
int16 getCursorAddress()
   int16 addr;
   glcd_sendCMD(GLCD_CMD_GET_CSR_ADDR);
   set_command();
   *(int8*)(&addr    ) = glcd_readByte();  // Read low part
   *((int8*)&addr + 1) = glcd_readByte();  // Read high part
   return addr;
// Purpose:    Set the cursor address
// Inputs:     A 16 bit integer containing the new cursor address
   glcd_sendCMD(GLCD_CMD_SET_CSR_ADDR);
   set_data();
   glcd_sendByte(*(int8*)(&addr    ));
   glcd_sendByte(*((int8*)&addr + 1));
// Purpose:    Get a byte of data from the display at the address
// Inputs:     A 16 bit integer containing the address
// Outputs:    An 8 bit integer with the read data
   setCursorAddress(addr);
   glcd_sendCMD(GLCD_CMD_DISPLAY_READ);
   set_command();
   return glcd_readByte();
// Purpose:    Set a byte of display data at an address
// Inputs:     1) A 16 bit address
//             2) 8 bits worth
   set_data();
   glcd_sendByte(data);
// Purpose:    Send an 8 bit command
// Inputs:     The command to send
   set_command();
   glcd_sendByte(cmd);
PostPosted: Sun Mar 28, 2010 10:52 pm     Reply with quote
#include <18F448.h>
What is your crystal or external oscillator frequency ?
dezso
PostPosted: Sun Mar 28, 2010 11:43 pm     Reply with quote
ok You got me on this one !
I just change it to see if the extra speed will help.
The code I compiled and shown on the video is using MPLAB config settings not the files config, 20MHz and running on 20MHz, not on 80MHz.
dezso
PostPosted: Sun Mar 28, 2010 11:47 pm     Reply with quote
The uTube video has some delay !?
Here is picture shows the uneven insensitivity of the word "Hello DDS"
dezso
PostPosted: Sun Mar 28, 2010 11:58 pm     Reply with quote
Currently I'm using 3 graphic layer, instead of the original.
   // Currently setup for all graphics layer
   glcd_sendByte(0x8);                          // All graphics
dezso
PostPosted: Mon Mar 29, 2010 12:16 am     Reply with quote
Just quickly recompiled one of earlier ASM test version.
No flicker, and I have not using any busy checking function.
http://www.youtube.com/watch?v=OTwgQ5_spKA
SEND_D1335_Command:
   Bsf   CMD_PORT,DA0
   Nop
SEND_D1335_Command_DATA:
   Movwf   DATA_PORT
   Nop
   Bsf   CMD_PORT,DRD
   Bcf   CMD_PORT,DCS
   Bcf   CMD_PORT,DWR
   Nop
   Bsf   CMD_PORT,DWR
   Bsf   CMD_PORT,DCS
   Return
WRITE32:   Bcf   CMD_PORT,DA0
   Call   SEND_D1335_Command_DATA
   Return
READ_DATA:   Movlw   0XFF
   Banksel   TRISD
   Movwf   TRISD
   Banksel   PORTD
   Bsf   CMD_PORT,DA0
   Bsf   CMD_PORT,DWR
   Bcf   CMD_PORT,DCS
   Bcf   CMD_PORT,DRD
   nop
   Movf   PORTD,W
   Movwf   D1
   nop
   Bsf   CMD_PORT,DRD
   nop
   Bsf   CMD_PORT,DCS
   Movlw   0X00
   Banksel   TRISD
   Movwf   TRISD
   Banksel   PORTD
   Return
PostPosted: Mon Mar 29, 2010 12:24 am     Reply with quote
Why post just a few routines from the ASM driver ?
If you say the ASM driver works and the CCS driver doesn't, then
do a side-by-side comparison of the ASM driver and the .LST file
from the CCS driver.
I assume you are testing these two drivers on the exact same board ?
The C driver has all this MAX749 code. Does the ASM driver have that ?
Make the most minimal possible program with both drivers, and also
try to call similar routines in each driver from the main program.
Then compare the behavior when they run, and compare the ASM
and .LST files.
You might also comment out the C source code in the CCS routines
and substitute #asm blocks with the ASM driver code instead.
In other words, get creative. Do anything required to trouble-shoot the
problem.
dezso
PostPosted: Mon Mar 29, 2010 9:23 am     Reply with quote
The ccs version works, unless I want less than 1 fps screen update.
Its extremely hard to read CCS ASM, I'm thinking to replace the sed1335.c with my complete asm driver.
Will see how that works.
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Mar 29, 2010 10:50 am     Reply with quote
I've seen the same problem on one of my old projects. Looks like you have a solution. If you can please share the ASM!
dezso
PostPosted: Mon Mar 29, 2010 5:41 pm     Reply with quote
Got is working, or at least now I find the differences between my method and the CCS.
I'll upload a short video for now, and try to make a presentable code for everyone here.
http://www.youtube.com/watch?v=t15ziQJ7K18
dezso
PostPosted: Tue Mar 30, 2010 3:39 pm     Reply with quote
Making progress, now the CCS modification works fine.
http://www.youtube.com/watch?v=2um5gaTOxWM
Had to change some of the basic structure, and added some new feature to the graphic lib.
http://rapidshare.com/files/370094860/SED_test.zip.html
dezso
PostPosted: Thu Apr 01, 2010 5:41 pm     Reply with quote
False alarm, its not perfect Grrrrrrr
I'm was reading this timing wrong or not.
The memory can be changed without effecting the display when D6 High ?
Also the rising edge need to be detected as well, otherwise the write could occurred a few ns before its start to read it again.
Cant figure out how long is the TC/R, my TC/R calculation based on the data sheet is: ((((osc/frame rate)/diplay heigh)/10)+10) = ((((12000000/70)/240)/10)+10) = dec 81 or 0x51. ?
My progress halted here, need some input.
