could somebody help me to check my code...
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
cokicoki
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger
PostPosted: Sun Mar 28, 2010 6:24 am     Reply with quote
i'm going to interface between GPS sensor with 16F877a....
with 38400 baudrate and 20Mhz....
i connecting gps tx to pic rx ang gps rx to pic tx....is it enough?...
this is my coding...can somebody help me out....it's appear nothing to my hyperterminal....somewhere might be wrong...but i couldn't trace it...:(
Locking.
Reason: PicBasic code is Off Topic
-- Forum Moderator
code:
DEFINE HSER_RCSTA 90h ' Enable serial port & continuous receive
DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH = 1
DEFINE HSER_SPBRG 77 ' 38400 Baud @ 0.16%
define HSER_BAUD 38400
DEFINE HSER_CLROERR 1 ' Clear overflow automatically
define OSC 20 'define the oscillator
rem variables
hh var byte
'include "modedefs.bas" 'include serial modes
gpsin var portc.7 'rx
gpsout var portc.6 'tx
gpsdata var portb.2
timeH var byte(2) 'variables define start
timeM var byte(2)
timeS var byte(2)
latD var byte(2)
latM var byte(2)
latS var byte(2)
latH var byte
lonD var byte(3)
lonM var byte(2)
lonS var byte(2)
lonH var byte
sats VAR BYTE(2)
sats2 VAR BYTE(2)
sats3 VAR BYTE(2)
sats4 VAR BYTE(2)
sats5 VAR BYTE(2)
sats6 VAR BYTE(2)
sats7 VAR BYTE(2)
sats8 VAR BYTE(2)
sats9 VAR BYTE(2)
sats10 VAR BYTE(2)
sats11 VAR BYTE(2)
sats12 VAR BYTE(2)
Diameter var byte(2)
Meg var byte(2)
Mode var byte(2)
spdI var byte
spdD var byte(2)
head var byte(3)
mon var byte(2)
day var byte(2)
yr var byte(2)
stat var byte
G var byte
D var byte
M var byte
A var byte
F var byte
GPGGA_IN var word
TEMPWORD var word
DEBOUNCE var byte
CMDACK var byte 'variable define end
start:
hserout ["GPS data:"]
gps:
SERIN2 portB.2,188,2000,Nogps,[WAIT("$"),str sats\1, STR sats2\1, STR sats3\1, STR sats4\1,_
str sats5\1, str sats6\1,str sats7\1, str sats8\1,_
str sats9\1, str sats10\1, str sats11\1, str sats12\1,_
skip 5, str dia\2, str mes\2, skip 26, str ano\2 ]
hserout [sats, sats2,sats3,sats4, sats5, sats6, sats7, sats8, sats9, sats10,sats11, sats12, diameter, Meg, Mode]
goto gps
Nogps:
hserout ["No GPS data"]
pause 2000
goto start
it's not working in my hyperterminal..help me please.....
Crying or Very sad
PostPosted: Sun Mar 28, 2010 6:51 am     Reply with quote
Wrong forum.
What you are posting, is _not_ CCS C code. You need to go to a forum dealing with the compiler you are using.
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
