Output File Names
Hans Wedemeyer
Output File Names
PostPosted: Thu Mar 25, 2010 8:09 am     Reply with quote
Sometimes one source can be used for several different mcu.
Is there a way to use a #define statement to output different file names ?
Or is there any way to change the output file names based upon some statement in the source code ?
PostPosted: Thu Mar 25, 2010 11:50 am     Reply with quote
You can use the #export directive to do this. The program shown below
creates the following file:
c:\program files\picc\projects\pch_test\myfile.hex
This was tested with vs. 4.106. I don't know if it works in your version.
#include <18F452.h>
#export(HEX, FILE=myfile.hex)
Hans Wedemeyer
Thanks that did the trick !
PostPosted: Fri Mar 26, 2010 10:28 am     Reply with quote
MikeW
PostPosted: Tue Mar 30, 2010 2:49 am     Reply with quote
I have been playing with PCM programmer's excellent suggestion of #export to have a more meaningful name for the hex file.
I have gotten as far as
#export(HEX, FILE= __date__ __FILENAME__ .hex)
which produces the hex file named
30-Mar-10rad_CPU_CAN_HMI_and_GLCD_Test_11.c
I have encountered 2 issue.
1. since the source code is name xxx.c, presumably windoz truncates to the first dot delimiter, and thus drops the ".hex".
2. cant use __TIME__ since windoz wont write a file with : in the name.
any suggestions ?
Mike
