connect pic to vb
kalman
connect pic to vb
PostPosted: Thu Mar 25, 2010 3:40 am     Reply with quote
Hi. I need to connect my pic to visual basic, VB.
I need them to send a value from my sensor through serial and display in VB application.
I'm using pic16f877a and PCWHD 4.084.
vb 6.0.
I need to know the connection and program both for PIC and VB.
I don't have experience to do this.
If anyone can give a reference please do.
LostInSpace
PostPosted: Thu Mar 25, 2010 6:29 pm     Reply with quote
A complete PIC application can be found here. You can search for VB code to talk to a serial port.
http://web.archive.org/web/20040603205840/www.geocities.com/hagtronics/pic_das/index.html
HTH - Steve H.
HTH - Steve H.
LostInSpace
PostPosted: Thu Mar 25, 2010 6:33 pm     Reply with quote
OK I see that the webarchive did not archive the source code. I have that code- if you want it you can go to my website: analoghome dot com and hit the link to send me an email - I'll send it to you.
HTH - Steve H.
karthickiw
reading data from serial port..
PostPosted: Fri Mar 26, 2010 5:45 am     Reply with quote
use mscomm object to revived the data from serial port.
1) first set band rate and port number in mscomm1 properties window.
2) Put timer1 object in to a form1 and set timer interval is 100 in properties window.
3) Put text box object in a form1.
4) double click the timer1 object, its go to code window.
5) put following code in to a code window
Private Sub Timer1_Timer()
text1.text = MSComm1.Input
End Sub
Cool Karthic
kalman
PostPosted: Fri Mar 26, 2010 7:54 pm     Reply with quote
how about the pic part
karthickiw
PostPosted: Fri Mar 26, 2010 10:25 pm     Reply with quote
just use printf statement.
example
printf("Hello CCS Friends");
Cool Karthic
