RTC rollover problem [solved]
turantus
PostPosted: Thu Mar 25, 2010 4:58 am     Reply with quote
Hi everyone. This is my first post but I read the forum for a long time.
Lets go with the problem... I use the CCS functions to work with the built-in Real Time Clock of the 18F26j11.
The RTC seems to work perfectly, but when it reaches the value 23:59:59 (day 1), the next value is 20:00:00 (day1) instead of 00:00:00 of the day2.
I have this problem with my own code and with the example of the CCS.
I don't know what to do.
This is a copy-paste of the hyperterminal:
ACTUAL 25/03/10 23:59:57
ACTUAL 25/03/10 23:59:58
ACTUAL 25/03/10 23:59:59
ACTUAL 25/03/10 20: 0: 0
ACTUAL 25/03/10 20: 0: 1
ACTUAL 25/03/10 20: 0: 2
ACTUAL 25/03/10 20: 0: 3
ACTUAL 25/03/10 20: 0: 4
ACTUAL 25/03/10 20: 0: 5
Thx for all.
turantus
PostPosted: Thu Mar 25, 2010 11:23 am     Reply with quote
Hi, I resolve the problem. The rtc_write( ) function don't work properly, I have to write the data by hand in BCD.
   #asm
   movlb   0x0f
   movlw   0x55
   movwf   EECON2
   movlw   0xAA
   movwf   EECON2
   BSF      RTCCFG,5
   #endasm
   RTCCFG =0xFF;
   RTCVALL=0x11;    //year
   RTCVALH=0x00;   //none
   RTCVALL=0x31;           //day month
   RTCVALH=0x12;   //month
   RTCVALL=0x23;           //hour
   RTCVALH=0x04;   //day of week
   RTCVALL=0x55;     //sec
   RTCVALH=0x59;   //min
I hope that will work for someone.
Cool
lokinhas
PostPosted: Fri Jul 23, 2010 11:08 am     Reply with quote
turantus thanks for the solution.
I had the same problem, and i solved it with your code.
You should change the PIC name to 18F26j11, so that people find this topic faster...
this is the code i used.
/*obtain bcd format of a decimal number*/
unsigned int8 bin_2_bcd(unsigned int8 num){
   unsigned int8 converted_num;
   converted_num=(num/10)<<4|(num%10);
   return converted_num;
void rtc_write_corrected(rtc_time_t write_clock){
   write_clock.tm_year=bin_2_bcd(write_clock.tm_year);    //year
   write_clock.tm_mday=bin_2_bcd(write_clock.tm_mday);   //day month
   write_clock.tm_mon=bin_2_bcd(write_clock.tm_mon);   //month
   write_clock.tm_hour=bin_2_bcd(write_clock.tm_hour);    //hour
   write_clock.tm_wday=bin_2_bcd(write_clock.tm_wday);      //day of week
   write_clock.tm_sec=bin_2_bcd(write_clock.tm_sec);    //sec
   write_clock.tm_min=bin_2_bcd(write_clock.tm_min);   //min
   #asm
   movlb   0x0f
   movlw   0x55
   movwf   EECON2
   movlw   0xAA
   movwf   EECON2
   BSF      RTCCFG,5
   #endasm
   RTCCFG =0xFF;
   RTCVALL=write_clock.tm_year;    //year
   RTCVALL=write_clock.tm_mday;   //day month
   RTCVALH=write_clock.tm_mon;   //month
   RTCVALL=write_clock.tm_hour;    //hour
   RTCVALH=write_clock.tm_wday;      //day of week
   RTCVALL=write_clock.tm_sec;    //sec
   RTCVALH=write_clock.tm_min;      //min
turantus
PostPosted: Fri Jul 23, 2010 2:49 pm     Reply with quote
hi lokinhas, really glad I have been helpful.
I encountered another problem, in this case with the RTC alarm.
With some numbers of seconds (I named it as "the seconds of the beast" ), RTC interrupt don´t work. I don´t search a solution, I only used other values.
Maybe writing the date of the alarm using the same method with the time...
Sorry for my "english"
