Problem in PIC16F877A
mapey87
PostPosted: Wed Mar 24, 2010 5:33 pm     Reply with quote
Anyone can help me? This is my program. I don't know what's wrong with it.
#include <16F877.h>
#device ADC=16
void main ()
unsigned int16 Range,total, i;
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
printf("Wetness value\n\r");
do{
   i = Read_ADC();
   Range=i*(6275/10000.0);
   printf("Value = %ld\n\r",i);
}while(true);
PostPosted: Wed Mar 24, 2010 6:24 pm     Reply with quote
#device ADC=16
Why are you using ADC=16 ? That will cause the ADC result to be
left-justified. Is that what you want ? Normally, people want the
result to be right-justified.
This will give you a 10-bit result, and it will be right-justified:
#device adc=10
mapey87
PostPosted: Wed Mar 24, 2010 8:25 pm     Reply with quote
I already change it. But the output I get is 163....The output that I want is from 0-15...or should I use float instead of int16?
PostPosted: Thu Mar 25, 2010 3:09 am     Reply with quote
First, as a comment, don't use ADC_CLOCK_INTERNAL. This is only designed for use, with clock rates below 1MHz, or if you put the processor to sleep, when performing the conversion. The 'correct' conversion clock for your 20MHz master clock, is:
ADC_CLOCK_DIV_32
This affects the accuracy slightly.
Now, your maths (6275/10000), effectively multiplies the ADC value by 0.6275. The ADC value is 0 to 1023, so it'll give numbers from 0 to 641. Nowhere near what you want....
It saves significant time to use integer arithmetic where possible, so something like:
   i = Read_ADC();
   Range=i*16; //Will give 0 to 16368
   printf("Value = %5.2lw\n\r"); //will print this as 0.00 to 16.36
