help in output file (.h)
rajabcomp2
PostPosted: Tue Mar 23, 2010 11:49 pm     Reply with quote
hi guys,
I am new in ccs c compiler, so that I would ask you when I build my program and it give me no error or warning.
That means the program doesn't have any error and I get the output, but my problem I couldn't find the hexadecimal file output.
You help in this please how can I get the hexadecimal file.
Thank you in advance Shocked Razz
robomaniac
PostPosted: Wed Mar 24, 2010 12:10 am     Reply with quote
In MPLAB IDE, when you can compile your code, the .hex file is generated directly in your project root directory. In the same place where your .c file is.
You can also use F3 in windows explorer and search for *.hex files.
When you have a error and your code does not compile, that will not create a .hex file. Not in your case.
Jérôme Demers
www.jeromedemers.com
rajabcomp2
PostPosted: Wed Mar 24, 2010 1:55 am     Reply with quote
Ok, let me say that. I tried to do what you had mentioned above, but no way to get it !!!
I didn't get any error, and the message below after the build all program
Memory usage: ROM=14% RAM=5% - 7%
0 Errors, 0 Warnings.
All what I got this as shown below
http://img339.imageshack.us/i/wallh.jpg/
and what is the benefit of *.list ???
CCS PCH C Compiler, Version 4.068, 2159               24-Mar-10 13:50
               Filename: wall.lst
               ROM used: 4332 bytes (14%)
                         Largest free fragment is 27600
               RAM used: 79 (5%) at main() level
                         114 (7%) worst case
               Stack:    5 worst case (4 in main + 1 for interrupts)
0000:  GOTO   08FA
0008:  MOVWF  05
000A:  MOVFF  FD8,06
000E:  MOVFF  FE0,07
0012:  MOVLB  0
0014:  MOVFF  FE9,0D
0018:  MOVFF  FEA,08
gil.fonea@sds-tech.com
PostPosted: Wed Mar 24, 2010 6:13 am     Reply with quote
I think it happened to me in the past. It means that your compiler did not even start executing a compilation. Check it.
Gil F.
