Athar Rasul
Posted: Sat Mar 20, 2010 2:41 pm |
| I want to call the function input() and assign the value it returns to input variable. Is that ok? |
Posted: Sat Mar 20, 2010 2:47 pm |
You are not allowed to assign anything to the function input().
You cannot name a variable with a reserved word such as the name of a
function. Change the name... _________________ Google and Forum Search are some of your best tools |
Athar Rasul
Posted: Sat Mar 20, 2010 3:15 pm |
Ok. I changed the name of function and variable. But it still gives error "expecting a numeric expression here" at the last line i.e. line containing '}'
| Code: | abc(){
int key,in;
start_input: lcd_putc("\f1:Temp Thresh.\n2:Level Thresh.");
key=wait_kbd_getc();
switch(key){
case 1: selection=1; lcd_putc("\fSet Temp(0-150)\n"); goto start_temp;
case 2: selection=2; lcd_putc("\rSet Level(0-100)\n"); goto start_level;
case '#': in=0; goto end_input;
default: goto start_input;
start_temp: key=wait_kbd_getc();
switch(key){
case '*': if(in>150){lcd_putc("\fOut of range...");
delay_ms(1000);in=0; lcd_putc("\fSet Temp(0-150)\n");
goto start_temp;}
else return(in);goto end_input;
case '#': in=0; goto start_input;
default: in=(in*10)+key; lcd_putc(key); goto start_temp;
start_level: key=wait_kbd_getc();
switch(key){
case '*': if(in>100){lcd_putc("\fOut of range...");
delay_ms(1000);in=0; lcd_putc("\fSet Level(0-100)\n");
goto start_level;}
default: in=(in*10)+key; lcd_putc(key); goto start_level;
in=0;
return(in);
end_input:
Posted: Sat Mar 20, 2010 4:34 pm |
As PCM told you earlier, you are going to have to do some of the work yourself.
Comment out sections of the code until it compiles then put them back one at at time until you find the culprit. _________________ Google and Forum Search are some of your best tools |
ferborghese
| problemas kbd.c puerto b pic16f887 |
Posted: Wed Mar 24, 2010 2:26 pm |
Search:
I am minded to a port where d pic16f887 have a 4x3 keypad and Nogra make it work, this project originally worked well with a PIC16F877A but we have a bad connection Reliz burn, and going to buy indicaroon us that this is the replacement and half cost.
I have to send two draft pic 16F877A with each other with the pic16f887 in each folder is a diagram of proteus 7.2 and ccs compiler used is used inside the MPLAB environment.
// PROYECTO FINAL DE CARRERA: "CONTROLADOR UNILAZO"
// ALUMNOS: RUBEN DAVID ALONSO, LEGAJO:
// BORGHESE FERNANDO ARIEL, LEGAJO: 4735.
// DIRECTOR DE PROYECTO:
// DESCRIPCION:
// CONTROLADOR PID, PI, PD, P, ANTI WIND-UP CON ENTRADA ANALOGICA 0 A 5 V, SALIDA PWM, DOS SALIDAS DIGITALES ALARMAS,
// i2c comuninacion conmemoria 24lc256 ,COMUNICACION RS232, ETHERNET.
#include <16F887.h>
#device adc=10
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#include <lcd.c>
#include <kbd.c>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK)
#include <stdlib.h>
#include "input.c"
#include "24256.c"
#include <math.h>
//*************************************** FUNCIONES UTILIZADAS *************************************
void SELECCION_TIPO_CONTROL(void);
void CONFIGURACION_CONTROL(void);
void FUNCIONAMIENTO_CONTROL(void);
void INICIALIZO_VDU(void);
void LEOENTRADA_ANALOGICA(void);
void CALCULO_ACTUACION_PID(void);
void CALCULO_ACTUACION_PD(void);
void CALCULO_ACTUACION_PI(void);
void CALCULO_ACTUACION_P(void);
void leo_r232_PID(void);
void leo_r232_PI(void);
void leo_r232_PD(void);
void leo_r232_P(void);
void salida_pwm(void);
void carga_SP(void);
void carga_KP(void);
void carga_KI(void);
void carga_A_AL(void);
void carga_A_BA(void);
void carg_kd(void);
// ***************** DECLARACION DE VARIABLES ******************************************************
char TIPO_CONTROL=' ',cambio_control=' ',sel=' ';
float sp=0,kp=0,kd=0,kii=0,error=0;
INT16 val232,tc=0;
float analogico=0,A_AL=0,A_BA=0,sum_error=0,error_ant=0,error_ant2=0,actuacion;
int tiemp=0;
long SALIDA=0;
// ************************************ FUNCIONAMIENTO DE CONTROL ***********************************
#int_rda // interrupcion para lectura por puerto serie
void interr_rs232(void)
if (kbhit()) // se pone en true si recibe algo por el puerto serie
tc=0; //tc=0 valor recibido por puerto serie
sel=getc(); // grabo el valor recido por el puerto serie en la variable sel
#int_TIMER0 //interrupcion del timer 0 en base al cual funciona el TM de control, y el TM de almacenamiento
void FUNCIONAMIENTO_control(void)
tiemp=tiemp+1;
LEOENTRADA_ANALOGICA(); //funcion de lectura de la entrada
switch (TIPO_CONTROL)
case '1': //si se sellecciono control PID
CALCULO_ACTUACION_PID();
SALIDA_PWM();
case '2': //si se sellecciono control PD
CALCULO_ACTUACION_PD();
SALIDA_PWM();
case '3': //si se sellecciono control PI
CALCULO_ACTUACION_PI();
SALIDA_PWM();
case '4': //si se sellecciono control P
CALCULO_ACTUACION_P();
SALIDA_PWM();
// ************************* MAIN ******************************************************************
setup_port_a(sAn0);
setup_adc(adc_clock_internal);
set_adc_channel(0);
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1,255, 1);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);// configura el timer0
// tiempo de muestreo = (32(rtc_div_x)/(4000000Mhz/4)(tiempo de un periodo))*256(resolucion del timer0 = 8 bits)= 8,192 ms
set_timer0(0);
kbd_init();
port_b_pullups(true);
SALIDA_PWM();
while (true)
SELECCION_TIPO_CONTROL();
CONFIGURACION_CONTROL();
while (cambio_control == ' ')
lcd_gotoxy(2,3);
printf(lcd_putc,"E:%lf",analogico);
printf(lcd_putc," S:%lu ",salida);
printf("\b\r %f",analogico);
if(analogico >= A_AL)
output_high(pin_C0); // ALARMA ALTA
output_low(pin_C0); // ALARMA ALTA
if(analogico <= A_BA)
output_high(pin_C5); // ALARMA BAJA
output_low(pin_C5); // ALARMA BAJA
if ((sel == 'S') || (sel == 'P') || (sel == 'I') || (sel == 'D') || (sel == 'V'))
disable_interrupts (INT_TIMER0);
disable_interrupts (INT_rda);
switch (sel)
case 'S':
sp=0;
carga_SP();
sel=' ';
tc=0;
case 'P':
kp=0;
carga_KP();
sel=' ';
tc=0;
case 'I':
kii=0;
carga_KI();
sel=' ';
tc=0;
case 'D':
kd=0;
carg_KD();
sel=' ';
tc=0;
case 'V':
TIPO_CONTROL=' ';
cambio_control=2;
sel=' ';
sp=0;
kp=0;
kii=0;
kd=0;
if (cambio_control!=2)INICIALIZO_VDU();
tc=0;
} //if principal
} //primer do
cambio_control=' ';
} //segundo do
} //cierre del main
// **************************************SELECCION TIPO DE CONTROL ***********************************
int stc=0;
// INICIALIZO LCD
lcd_putc("SEL.CONTROLADOR\n");
lcd_putc("1PID 2PD 3PI 5ID");
// INICIALIZO PANTALLA
printf("\r\n SELECCIONAR CONTROLADOR \r\n");
printf(" 1 - PID.\r\n");
printf(" 2 - PD.\r\n");
printf(" 3 - PI.\r\n");
printf(" 4 - P.\r\n");
while (stc == 0)
// LECTURA DE VDU
if (kbhit())
TIPO_CONTROL=getch();
if ((TIPO_CONTROL == '1') || (TIPO_CONTROL == '2') || (TIPO_CONTROL == '3') || (TIPO_CONTROL == '4') || (TIPO_CONTROL == '5'))
stc=1;
// LECTURA DE TECLADO
TIPO_CONTROL=kbd_getc();
if ((TIPO_CONTROL == '1') || (TIPO_CONTROL == '2') ||(TIPO_CONTROL == '3') || (TIPO_CONTROL == '4') || (TIPO_CONTROL == '5'))
{ tc=1;
stc=1;
// cambio_control=' ';
//************************************ CONFIGURACION DE CONTROL********************************
case '1':
carga_SP();
carga_KP();
carga_KI();
carg_KD();
// MUESTRA EN PANTALLA VDU
INICIALIZO_VDU();
// MUESTRA EN PANTALLA LCD
lcd_gotoxy(0,1);
printf(lcd_putc," PID Sp:%f",sp);
case '2':
carga_SP();
carga_KP();
carg_Kd();
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," PD Sp:%f",sp);
case '3':
carga_SP();
carga_KP();
carga_KI();
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," PI Sp:%f",sp);
case '4':
carga_SP();
carga_KP();
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," P Sp:%f",sp);
carga_A_BA();
carga_A_AL();
clear_interrupt(INT_TIMER0);
clear_interrupt(int_rda);
clear_interrupt(int_EXT);
enable_interrupts(int_rda); //habilita interrupcion
enable_interrupts(int_EXT); //habilita interrupcion
//**************************** FUNCION DE LECTURA DE ENTRADA ANALOGICA *****************************
analogico=read_adc();
// *************************** calculo de control **************************************************
error=(sp-analogico);
sum_error=((kp+((kp*kd)/8))*error)+ (((kp*8)/kii)-kp-(2*kp*(kd/8)))*error_ant;
actuacion=sum_error+(kp*(kd/8))*error_ant2+actuacion;
error_ant2=error_ant;
error_ant=error;
if (actuacion >= 1023)
SALIDA =(long)1023;
if (actuacion >= 3096)
ACTUACION=1023;
else if (actuacion <= -1)
SALIDA =(long)0;
if (actuacion <= -3096)
ACTUACION=0;
SALIDA=(long)actuacion;
actuacion=kp*(error+(kd/1)*(error-error_ant))+actuacion;
error_ant=error;
SALIDA =(long)1023;
ACTUACION=1023;
SALIDA =(long)0;
ACTUACION=0;
actuacion=kp*error+(((8/kii)-KP)*error_ant)+actuacion;
error_ant=error;
SALIDA =(long)1023;
ACTUACION=1023;
SALIDA =(long)0;
ACTUACION=0;
actuacion=(kp*error);
SALIDA =(long)1023;
ACTUACION=1023;
SALIDA =(long)0;
ACTUACION=0;
//*********************************** funcion salida analica pwm **********************************
void SALIDA_PWM(void)
set_pwm1_duty(salida);
//************************************ INICIALIZO VDU *********************************************
printf("\r\nCONTROL PID\r\n");
printf(" S - SETEAR SET POINT:%f\r\n",sp);
printf(" P - MODIFICAR KP:%f\r\n", Kp);
printf(" I - MODIFICAR KI:%f\r\n", Kii);
printf(" D - MODIFICAR KD:%f\r\n", Kd);
printf(" V - DETENER Y SELECCIONAR TIPO DE CONTROL \r\r\n");
printf("\r\nCONTROL PD\r\n");
printf("\r\nCONTROL PI\r\n");
printf("\r\nCONTROL P\r\n");
// ********************************* FUNCION DE LECTURA RS232 *************************************
char seleccion;
val232=' ';
seleccion=getch();
switch (seleccion)
case 'S':
carga_SP();
case 'P':
carga_KP();
case 'I':
carga_KI();
case 'D':
carg_KD();
case 'V': disable_interrupts (INT_TIMER0);
TIPO_CONTROL=' ';
cambio_control=2;
if ((seleccion == 'S') || (seleccion == 'P') || (seleccion == 'I') || (seleccion == 'D'))
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," PID Sp:%f\n\r",sp);
lcd_gotoxy(0,0);
char seleccion;
val232=' ';
seleccion=getch();
switch (seleccion)
case 'S':
carga_SP();
case 'P':
carga_KP();
case 'I':
carga_KI();
TIPO_CONTROL=' ';
cambio_control=2;
if ((seleccion == 'S') || (seleccion == 'P') || (seleccion == 'I'))
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," PI Sp:%f\n\r",sp);
lcd_gotoxy(0,0);
char seleccion;
val232=' ';
seleccion=getch();
switch (seleccion)
case 'S':
carga_SP();
case 'P':
carga_KP();
TIPO_CONTROL=' ';
cambio_control=2;
if ((seleccion == 'S') || (seleccion == 'P'))
INICIALIZO_VDU();
lcd_gotoxy(0,1);
printf(lcd_putc," P Sp:%f\n\r",sp);
lcd_gotoxy(0,0);
void carga_SP(void)
printf("\r\n Seleccion set point:");
lcd_gotoxy(0,1);
printf(lcd_putc," CARGA SP: ");
do{
if (kbhit()) // si recibi un caracter por el puerto 232= true
sp=get_float();
if (tc == 1)
sp=get_float_kbd();
} while(sp==0);
void carga_KP(void)
printf("\r\n Seleccion Constante Proporcional:");
lcd_gotoxy(0,1);
printf(lcd_putc," CARGA KP: ");
do{
kp=get_float();
if (tc == 1)
kp=get_float_kbd();
} while(kp==0);
void carg_KD(void)
printf("\r\n Seleccion Constante Derivativa:");
lcd_gotoxy(0,1);
printf(lcd_putc," CARGA KD: ");
do{
kd=get_float();
if (tc == 1)
kd=get_float_kbd();
} while(kd==0);
void carga_KI(void)
printf("\r\n Seleccion Constante Integral:");
lcd_gotoxy(0,1);
printf(lcd_putc," CARGA KI: ");
do{
kii=get_float();
if (tc == 1)
kii=get_float_kbd();
} while(kii==0); while(sp==0);
void carga_KD(void)
lcd_gotoxy(0,1);
do{
kd=get_float();
if (tc == 1)
kd=get_float_kbd();
} while(kd==0);
printf("\r\n CARGA A_BA:");
lcd_gotoxy(0,1);
printf(lcd_putc," C A_BA: ");
do{
A_BA=get_float();
if (tc == 1)
A_BA=get_float_kbd();
} while(A_BA==0);
printf("\r\n CARGA A_AL:");
lcd_gotoxy(0,1);
printf(lcd_putc," C.A_AL: ");
do{
A_AL=get_float();
if (tc == 1)
A_AL=get_float_kbd();
} while(A_AL==0);
From already thank you very much.
Greetings |
