pulse signal generator, help?
attheedge
PostPosted: Wed Mar 17, 2010 5:10 pm     Reply with quote
Hello everybody,
I'm trying to write a pulse signal generator in CCS C. This generator will start with a button press and pulse has characteristics like 200us HIGH, 9800us LOW, means in otherwords it has 100Hz frequency. And also pulse will stop after 30 minutes.
I tried some solutions but I can not set the correct timing. Please help.
PostPosted: Wed Mar 17, 2010 5:22 pm     Reply with quote
See these CCS example files:
c:\program files\picc\examples\ex_pgen.c
c:\program files\picc\examples\ex_ccp1s.c
You can use one of these button routines:
Here is a simple routine that waits for a button press:
http://www.ccsinfo.com/forum/viewtopic.php?t=19874
Here is the "Button Command" code that I wrote for the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=23837
