Ikk06
Piezo sensors |
Posted: Tue Mar 16, 2010 7:40 pm |
Hi
I was building a drum kit using piezo sensors. I am using a pic 18f4420 with an analogue to digital input. The circuit is connected to the computer using a midi usb cable. I am using putc() to send signals to the computer. What I wanted to know was how the analogue signals are read into the pic as they are not just on(1) or off(0). If anyone has any sample code that shows how the signals are read and used I would appreciate it. |
Ikk06
Posted: Wed Mar 17, 2010 10:08 am |
This is the code that I currently have to setup the adc and read from it the digital value. Based on this value I want to send a diffrent output to the computer via the midi calbe. Have I set this up correctly??
#include <stdio.h>
#include <stdlib.h>
int x;
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_adc(ADC_CLOCK_INTERNAL); //enables the a/d module and sets the clock to internal adc clock
setup_adc_ports(ALL_ANALOG); //sets all the adc pins to analog
set_adc_channel(0); //the next read_adc call will read channel 0
delay_us(10);
While(1)
x=read_adc(A0); //starts the conversion and reads the result and store it in x
If (x>100)
else If (100<x<=200)
putc (0xFF);
else If (200<x<=300)
putc (0xFF);
else If (300<x<=400)
putc (0xFF);
else If (400<x<=500)
putc (0xFF);
else If (500<x<=600)
putc (0xFF);
else if (600<x<=700)
putc (0xFF);
else If (700<x<=800)
putc (0xFF);
else If (800<x<=900)
putc (0xFF);
else If (900<x<=1000)
putc (0xFF);
else if (1000<x)
putc (0xFF);
putc(0x80); /* Transmits the midi signal for sound off */
bungee-
Posted: Wed Mar 17, 2010 10:31 am |
Write what would you like to achieve with that code. On first glance, it will not work.
int x <== 8 bit value, there you can put only 255 not more.
Then if you want to send for values larger that 100 an 0xFF you can do it with one simple if sentence.
if (x>100) putc(0xff)
else putc(0x80);
And remember x must be declared as: int16 x; |
Ikk06
Posted: Wed Mar 17, 2010 10:46 am |
What I am basically building is a drum kit using a piezo sensor which is connected to the circuit and then onto the computer via a midi cable. What I want the code to do is when the sensor is hit it gives an analogue reading which should be converted to a 10 bit digital reading due to the ADC. The If functions are supposed to send out a midi signal to the computer via the midi usb cable based on the reading of the 10 bit digital signal. All the If functions show is what signal to send when the digital reading is in which range. All the midi signals are the same at the moment because I wanted to check if it was working. This is the code with the alterations.
#include <stdio.h>
#include <stdlib.h>
int16 x;
setup_vref(FALSE);
delay_us(10);
While(1)
x=read_adc(AN0); //starts the conversion and reads the result and store it in x
If (x>100)
putc (0xFF);
putc (0xEE);
putc (0xDD);
putc (0xCC);
putc (0xBB);
putc (0xAA);
putc (0x99);
putc (0x88);
putc (0x77);
putc (0x66);
else if (1000<x)
putc (0x55);
What do I need to change?? |
bungee-
Posted: Wed Mar 17, 2010 1:39 pm |
With all that if else compiler get confused and in middle of all compiles your code in some strange manner.
And when I'm looking at your code, there is something wrong with the logic. If x is larger than 100 (x>100) then you put 0xff to output, and then you exit ...
try to code like that:
Code: | if (20>x) putc(0x80);
If (20<x<=100) putc (0xFF);
If (100<x<=200) putc (0xEE);
If (200<x<=300) putc (0xDD);
If (300<x<=400) putc (0xCC);
If (400<x<=500) putc (0xBB);
If (500<x<=600) putc (0xAA);
if (600<x<=700) putc (0x99);
If (700<x<=800) putc (0x88);
If (800<x<=900) putc (0x77);
If (900<x<=1000) putc (0x66);
if (1000>x) putc (0x55); |
It covers all the AD range, so you don't need the if else structure. Also you did not supply fuses etc, that we could see if something is wrong in there also.
Why do you need stdio and stdlib? habit from PC world, you can avoid them here if you don't need some function from there. |
Ikk06
Posted: Thu Mar 18, 2010 8:05 am |
The fuses are in a different file which is included into this one.
#include <18F4420.h>
#FUSES INTRC_IO //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use rs232(baud=3125,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8) |
The code with the alterations looks like this now:
#include "Y:\Year3\Project\Program\Project\Project2.h"
#include <stdio.h>
#include <stdlib.h>
int16 x;
setup_vref(FALSE);
delay_us(10);
While(1)
x=read_adc(AN0); //starts the conversion and reads the result from AN0 and stores it in x
if (20<x<=100) putc (0xFF);
if (100<x<=200) putc (0xEE);
if (200<x<=300) putc (0xDD);
if (300<x<=400) putc (0xCC);
if (400<x<=500) putc (0xBB);
if (500<x<=600) putc (0xAA);
if (700<x<=800) putc (0x88);
if (800<x<=900) putc (0x77);
if (900<x<=1000) putc (0x66);
Is this right?? |
