TselelTJ
4 Decimal, 7-Segment counter (0-9999) |
Posted: Wed Mar 10, 2010 11:27 am |
Good Day ppl.
I'm taking my baby steps with ccs code.
May somebody help me with the code for the following:
The cct must count from 0 to 9999 and it uses a switch which stops the count at any moment, when switch closes it starts again at 0.
1. PIC18F2220
2. Switch at RC0.
3. Bus Wire [RB0-RB7] to U1-U4 (74HC373)
4. Four 7-Segment displays (Common Anode)
5. RC1-RC4 LE wires to U1-U4 (74HC373)
6. OE is Grounded (74HC373)
Thanks in advance. |
TselelTJ
Posted: Fri Mar 12, 2010 3:26 am |
I was able to do the ff but now i need help with the switch, If the switch is open all segments must be off and when closed it must start from 0.
#include "Counter_7Seg.h"
char map[10]={0xc0,oxf9,0xa4,0xb0,0x99,0x82,0xf8,0x80,0x09};
void main (){
int i, j, k, l;
port_b_pullups(TRUE);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_comparator (NC_NC_NC);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
i=0;
j=0;
k=0;
l=0;
if(input(PIN_C0))
output_b(map[i]);
output_high(PIN_C4);
delay_ms(30);
output_low(PIN_C4);
if(input(PIN_C0))
output_b(map[j]);
output_high(PIN_C3);
delay_ms(30);
output_low(PIN_C3);
if(input(PIN_C0))
output_b(map[k]);
output_high(PIN_C2);
delay_ms(30);
output_low(PIN_C2);
if(input(PIN_C0))
output_b(map[l]);
output_high(PIN_C1);
delay_ms(30);
output_low(PIN_C1);
if(i<10)
i++;
if(i==10)
j++;
i=0;
if(j==10)
k++;
j=0;
if(k==10)
l++;
j=0;
if(l==10)
i=0;
j=0;
k=0;
l=0;}
jbmiller
Joined: 07 Oct 2006 Posts: 73 Location: Greensville,Ontario
Posted: Sun Mar 14, 2010 7:09 am |
Just a tip on coding...
It'll help if you name variables with what they mean instead of i,j,k,...
Same goes true for I/P pins...tens_digit,ones_digit,....
While you may remember them for the next few days, a week or so from now, you'll be asking, What does this mean !! Been there..did that !
It also helps everyone else trying to help you out !
Also if you need to reassign a pin, it can be done with one line of code at the beginning, instead of looking for all of them in a few hundred lines of code!
Hope this helps
TselelTJ
Posted: Thu Mar 18, 2010 8:17 am |
Here is the working code, I finally got it right...
Code: | #include "Assignment.h"
char map[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void main(){
int8 DD1=0, DD2=0, DD3=0, DD4=0;
setup_wdt(WDT_OFF);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
if(input(PIN_C0))
output_b(0xff);
output_b(map[DD1]);
delay_ms(30);
output_low(PIN_C4);
output_b(map[DD2]);
delay_ms(30);
output_low(PIN_C3);
output_b(map[DD3]);
delay_ms(30);
output_low(PIN_C2);
output_b(map[DD4]);
delay_ms(30);
output_low(PIN_C1);
if(DD1<10)
DD1++;
if(DD1==10)
DD1=0;
DD2++;
if(DD2==10)
DD2=0;
DD3++;
if(DD3==10)
DD3=0;
DD4++;
if(DD4==10)
DD4=0;
output_b(0xff);
DD1=0;
DD2=0;
DD3=0;
DD4=0;
