I am very new to PIC microcontroller and very little knowledge.
I am trying to read 2 analog sources (potentiometer and proximity sensor) and convert them to digital values.
All the samples I found are reading from one source.
Could someone point me to the right direction and help me understand how it works.
For example: (say I want to read from A0 and A1 inputs, how do I get two readings?)
setup_adc(ALL_ANALOG); //sets porta toall analog inputs
set_adc_channel(1); //points a/d at channel 1
delay_ms(5000); //waits 5 seconds
value = read_adc(); //reads value
Thanks in advance,
Kevin
Posted: Fri Mar 12, 2010 12:17 pm
Set the channel. Wait for a short delay (not 5 seconds). Then read
the A/D value into a variable. Example:
