chrispol
Embedded ethernet board spi and mcp3301 |
Posted: Wed Mar 10, 2010 2:09 pm |
I can't seem to communicate with a mcp3301 on spi, below is a test app
Code: | #include <18F4620.h>
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#use delay(clock=40000000)
#define MCP3301_CS PIN_B4
#define MCP3301_SDO PIN_C4
#define MCP3301_CLK PIN_C3
void init_mcp3301()
output_high(MCP3301_CLK);
output_high(MCP3301_CS);
setup_spi( SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 );
BYTE read_adc_byte(BYTE number_of_bits)
BYTE i,data;
data=0;
for(i=0;i<number_of_bits;++i)
output_low(MCP3301_CLK);
delay_us(25);
shift_left(&data,1,input(MCP3301_SDO));
delay_us(25);
return(data);
signed long read_mcp3301()
signed long out_value;
BYTE byte_low=0,byte_high=0;
output_low(MCP3301_CS);
byte_high=read_adc_byte(8);
byte_low=read_adc_byte(5);
out_value = make16(byte_high,byte_low);
if(bit_test(out_value,12))
{bit_set(out_value,15);}
{bit_clear(out_value,15);}
return out_value & 0x9FFF;
signed long adc_value;
port_b_pullups(TRUE);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
init_mcp3301();
for(;;)
//TcpIpTask();
adc_value = read_mcp3301();
printf("adc_value: %Ld \r\n",adc_value); // Signed output
Anyone have any ideas? |
Posted: Wed Mar 10, 2010 2:42 pm |
You're mixing hardware SPI with software SPI. You need to choose
which one you want to use.
Most of your code is written for software SPI. If that's what you want
to use, then you should delete the setup_spi() line.
If you want to use hardware SPI, the MCP3301 data sheet explains
how to do it in this section:
Quote: |
7.3 Using the MCP3301 with
Microcontroller (MCU) SPI Ports
If that doesn't help, then post a list of the connections between the PIC
and the MCP3301 chip. Post the actual pin numbers, not the pin names. |
