#DEVICE ADC = 10-Can not change device type this far into
Boyce
PostPosted: Tue Mar 09, 2010 7:07 pm     Reply with quote
Compiler PCW 4.104 Device 16F690
How is #DEVICE ADC = 10 applied?
When I put it in my code, the error
"Can not change device type this far into the code"
pops up.
What can I do to change this? Does this go in the 16F690.h file?
Thanks,
Boyce
Here is the code:
int16 T0, T2, T3;//Leave off T1 as AN1 is the reference
int Dt1, Dt2, Dt3;
#DEVICE ADC=10 //<<<===Error shown here...
   setup_adc_ports(sAN0|sAN2|sAN3|VSS_VREF);//AN0 is the ADC voltage reference
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
   //Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   for(;;)
      set_adc_channel(0);//0 for AN0, 1 for AN1...
      delay_us(10);
      T0 = make8((read_adc()),0);
      //REMEMBER, AN1 IS THE REFERENCE ON A 16F690
      set_adc_channel(2);//0 for AN0, 1 for AN1...
      delay_us(10);
      T2 = make8((read_adc()),0);
      output_C(T2);//Output lower 8 bits of T2
      //output_C(T1-T2)
   }//end for(;;)
}//end main
boyceg1@gmail.com
PostPosted: Tue Mar 09, 2010 8:10 pm     Reply with quote
Put all #device statements immediately after the #include line for the PIC.
That's what it means.
Boyce
PostPosted: Tue Mar 09, 2010 11:43 pm     Reply with quote
Or put it in the 16F690.h file were the #device adc = 8 is. Change the 8 to 10. Works.
Thanks for the suggestion.
Boyce
boyceg1@gmail.com
LostInSpace
PostPosted: Wed Mar 10, 2010 12:13 am     Reply with quote
The downside of changing supplied .h files is that with a new compiler install you will overwrite your modifications and your code may not work as expected. Or another programmer might not get your modified .h file.
If you do this (see snippet below) it will work and be in your main .c file so that everyone will know what is happening.
// Device setup
#include <16F688.h>
#device *=16
#device adc=8
// Fuses, etc.
#FUSES WDT
HTH - My 2 cents worth.
Boyce
PostPosted: Wed Mar 10, 2010 7:11 pm     Reply with quote
Sorry, I was mistaken when I said #DEVICE ADC = 10 was in the 16F690.h file.
Actually, it is in the main.h file. The main.h file contains the following:
#include <16F690.h>
#device adc=10
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES RESERVED                 //Used to set the reserved FUSE bits
I don't think PCW 4.104 will let me put #DEVICE in the main.c file at all. Been wrong before.
Boyce
boyceg1@gmail.com
