printf float doesn't work
kalman
PostPosted: Mon Mar 08, 2010 9:13 pm     Reply with quote
Good day, I have got this printf problem when I try simulating with Proteus.
Using pcwhd 4.084
#include <16f877a.H>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT,NOLVP
#define INTS_PER_SECOND 60
long count;
#int_rtcc
void clock_isr() {
      ++count;
   long start,diff;
   float dt;
   set_timer0(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
   enable_interrupts(INT_RTCC);
   do {
      start=count;
      getc();
      diff=count-start;
      dt=(diff)/60;
      printf("%Ld %Ld %6.4f seconds.\n\r",count,start,dt);
   } while (TRUE);
For example, start=0, count=133;
the value dt should be 2.2166, but it only shows 2.
Did I miss something there?
Jerson
PostPosted: Tue Mar 09, 2010 7:23 am     Reply with quote
change this
      dt=(diff)/60;
to this
      dt=(float)diff/60;
and you'll get the result you want
kalman
PostPosted: Tue Mar 09, 2010 8:25 am     Reply with quote
wow, thanks
