Shine Guest
thick display fonts for K0108 based LCD |
Posted: Mon Mar 08, 2010 4:56 am |
Can anyone please help me on the below code, its the same CCS example code with some modification for rendering bitmap fonts.
Can anyone please identify why the LCD is not showing any letter?
I'm using the additional functions - glcd_text() & glcd_glyph()
#include <18F452.h>
#include "HDM64GS12.c"
char str[10];
strcpy(str,"W");
glcd_init(ON);
glcd_Text(10,10,str);
glcd_updateA();
#include <stdint.h>
#include <stdlib.h>
#ifndef HDM64GS12
#define HDM64GS12
#ifndef GLCD_WIDTH
#define GLCD_WIDTH 128
#ifndef GLCD_CS1
#define GLCD_CS1 PIN_B1 // Chip Selection 1
#ifndef GLCD_CS2
#define GLCD_CS2 PIN_B0 // Chip Selection 2
#ifndef GLCD_DI
#define GLCD_DI PIN_B2 // Data or Instruction input
#ifndef GLCD_RW
#define GLCD_RW PIN_B3 // Read/Write
#ifndef GLCD_E
#define GLCD_E PIN_B4 // Enable
#ifndef GLCD_RST
#define GLCD_RST PIN_B5 // Reset
#define GLCD_LEFT 0
#define GLCD_RIGHT 1
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
/* LCD screen and bitmap image array consants */
#define X_BYTES 127
#define Y_BYTES 8
#define SCRN_LEFT 0
#define SCRN_TOP 0
#define SCRN_RIGHT 127
#define SCRN_BOTTOM 63
/* display definition */
#define GLCD_NUMCONTROLLER 2
#define GLCD_NUMCONTROLLERX 2
#define GLCD_NUMCONTROLLERY 1
#define GLCD_MAXPAGE 8
#define GLCD_MAXADDRESS 64
#define GLCD_LEFTA 0
#define GLCD_TOP 0
#define GLCD_RIGHTA (GLCD_NUMCONTROLLERX*GLCD_MAXADDRESS-1)
#define GLCD_BOTTOM (GLCD_NUMCONTROLLERY*GLCD_MAXPAGE*8-1)
#define GLCD_MODE_NORMAL 0
#define GLCD_MODE_INVERTED 1
#define GLCD_MODE_CLEAR 0
#define GLCD_MODE_SET 1
#define GLCD_MODE_XOR 2
#define GLCD_CLEAR_BUFFER 0
#define GLCD_CLEAR_ALL 1
#define GLCD_ON 0x3F
#define GLCD_DISP_START0 0xC0
#define GLCD_SET_PAGE 0xB8
#define GLCD_SET_ADDRESS 0x40
#define GLCD_X_BYTES (GLCD_NUMCONTROLLERX*GLCD_MAXADDRESS)
#define GLCD_Y_BYTES (GLCD_NUMCONTROLLERY*GLCD_MAXPAGE)
#define GLCD_SELECTNONE 99
/* define number labels for the font selections */
const uint8_t five_dot_glyph_table[] = {
/* ' ' charwidth: 2 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '!' charwidth: 2 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* '"' charwidth: 4 */
0x00, /* [ ] */
0xA0, /* [* * ] */
0xA0, /* [* * ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '#' charwidth: 8 */
0x00, /* [ ] */
0x14, /* [ * * ] */
0x7E, /* [ ****** ] */
0x28, /* [ * * ] */
0xFC, /* [****** ] */
0x50, /* [ * * ] */
0x00, /* [ ] */
/* '$' charwidth: 4 */
0x40, /* [ * ] */
0x60, /* [ ** ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0xC0, /* [** ] */
0x40, /* [ * ] */
/* '%' charwidth: 8 */
0x00, /* [ ] */
0x64, /* [ ** * ] */
0xA8, /* [* * * ] */
0xD6, /* [** * ** ] */
0x2A, /* [ * * * ] */
0x4C, /* [ * ** ] */
0x00, /* [ ] */
/* '&' charwidth: 6 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x40, /* [ * ] */
0x98, /* [* ** ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* ''' charwidth: 2 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '(' charwidth: 3 */
0x40, /* [ * ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x40, /* [ * ] */
/* ')' charwidth: 3 */
0x80, /* [* ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
/* '*' charwidth: 6 */
0x00, /* [ ] */
0x50, /* [ * * ] */
0x20, /* [ * ] */
0xF8, /* [***** ] */
0x20, /* [ * ] */
0x50, /* [ * * ] */
0x00, /* [ ] */
/* '+' charwidth: 6 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* ',' charwidth: 3 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
/* '-' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '.' charwidth: 2 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* '/' charwidth: 4 */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* '0' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* '1' charwidth: 3 */
0x00, /* [ ] */
0x40, /* [ * ] */
0xC0, /* [** ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* '2' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0xF0, /* [**** ] */
0x00, /* [ ] */
/* '3' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x20, /* [ * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* '4' charwidth: 5 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x60, /* [ ** ] */
0xA0, /* [* * ] */
0xF0, /* [**** ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* '5' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x20, /* [ * ] */
0xC0, /* [** ] */
0x00, /* [ ] */
/* '6' charwidth: 5 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* '7' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* '8' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* '9' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* ':' charwidth: 2 */
0x00, /* [ ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* ';' charwidth: 3 */
0x00, /* [ ] */
0x00, /* [ ] */
0x40, /* [ * ] */
0x00, /* [ ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
/* '<' charwidth: 4 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* '=' charwidth: 5 */
0x00, /* [ ] */
0x00, /* [ ] */
0xF0, /* [**** ] */
0x00, /* [ ] */
0xF0, /* [**** ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '>' charwidth: 4 */
0x00, /* [ ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* '?' charwidth: 4 */
0x00, /* [ ] */
0xC0, /* [** ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* '@' charwidth: 8 */
0x38, /* [ *** ] */
0x44, /* [ * * ] */
0x9A, /* [* ** * ] */
0xAA, /* [* * * * ] */
0xB4, /* [* ** * ] */
0x40, /* [ * ] */
0x30, /* [ ** ] */
/* 'A' charwidth: 6 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x50, /* [ * * ] */
0x70, /* [ *** ] */
0x88, /* [* * ] */
0x00, /* [ ] */
/* 'B' charwidth: 5 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* 'C' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x80, /* [* ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'D' charwidth: 5 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* 'E' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* 'F' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'G' charwidth: 5 */
0x00, /* [ ] */
0x70, /* [ *** ] */
0x80, /* [* ] */
0xB0, /* [* ** ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x00, /* [ ] */
/* 'H' charwidth: 5 */
0x00, /* [ ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0xF0, /* [**** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'I' charwidth: 2 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'J' charwidth: 5 */
0x00, /* [ ] */
0x10, /* [ * ] */
0x10, /* [ * ] */
0x10, /* [ * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'K' charwidth: 5 */
0x00, /* [ ] */
0x90, /* [* * ] */
0xA0, /* [* * ] */
0xC0, /* [** ] */
0xA0, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'L' charwidth: 4 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* 'M' charwidth: 6 */
0x00, /* [ ] */
0x88, /* [* * ] */
0xD8, /* [** ** ] */
0x88, /* [* * ] */
0x88, /* [* * ] */
0x00, /* [ ] */
/* 'N' charwidth: 6 */
0x00, /* [ ] */
0x88, /* [* * ] */
0xC8, /* [** * ] */
0x98, /* [* ** ] */
0x88, /* [* * ] */
0x00, /* [ ] */
/* 'O' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'P' charwidth: 5 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'Q' charwidth: 5 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x10, /* [ * ] */
/* 'R' charwidth: 5 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0xA0, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'S' charwidth: 4 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0xC0, /* [** ] */
0x00, /* [ ] */
/* 'T' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* 'U' charwidth: 5 */
0x00, /* [ ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'V' charwidth: 6 */
0x00, /* [ ] */
0x88, /* [* * ] */
0x50, /* [ * * ] */
0x50, /* [ * * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* 'W' charwidth: 8 */
0x00, /* [ ] */
0x82, /* [* * ] */
0x54, /* [ * * * ] */
0x28, /* [ * * ] */
0x28, /* [ * * ] */
0x00, /* [ ] */
/* 'X' charwidth: 6 */
0x00, /* [ ] */
0x88, /* [* * ] */
0x50, /* [ * * ] */
0x20, /* [ * ] */
0x50, /* [ * * ] */
0x88, /* [* * ] */
0x00, /* [ ] */
/* 'Y' charwidth: 6 */
0x00, /* [ ] */
0x88, /* [* * ] */
0x50, /* [ * * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* 'Z' charwidth: 4 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* '[' charwidth: 3 */
0xC0, /* [** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0xC0, /* [** ] */
/* '\' charwidth: 4 */
0x80, /* [* ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0x20, /* [ * ] */
0x00, /* [ ] */
/* ']' charwidth: 3 */
0xC0, /* [** ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0xC0, /* [** ] */
/* '^' charwidth: 6 */
0x00, /* [ ] */
0x20, /* [ * ] */
0x50, /* [ * * ] */
0x88, /* [* * ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '_' charwidth: 6 */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* '`' charwidth: 3 */
0x00, /* [ ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
/* 'a' charwidth: 5 */
0x00, /* [ ] */
0x00, /* [ ] */
0x70, /* [ *** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x00, /* [ ] */
/* 'b' charwidth: 5 */
0x00, /* [ ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* 'c' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'd' charwidth: 5 */
0x00, /* [ ] */
0x10, /* [ * ] */
0x70, /* [ *** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x00, /* [ ] */
/* 'e' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0x60, /* [ ** ] */
0xA0, /* [* * ] */
0xC0, /* [** ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'f' charwidth: 4 */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x80, /* [* ] */
0xC0, /* [** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'g' charwidth: 5 */
0x00, /* [ ] */
0x70, /* [ *** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x10, /* [ * ] */
0x60, /* [ ** ] */
/* 'h' charwidth: 5 */
0x00, /* [ ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'i' charwidth: 2 */
0x80, /* [* ] */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'j' charwidth: 3 */
0x40, /* [ * ] */
0x00, /* [ ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
/* 'k' charwidth: 5 */
0x00, /* [ ] */
0x80, /* [* ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0xA0, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'l' charwidth: 2 */
0x00, /* [ ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 'm' charwidth: 6 */
0x00, /* [ ] */
0x00, /* [ ] */
0xF0, /* [**** ] */
0x00, /* [ ] */
/* 'n' charwidth: 5 */
0x00, /* [ ] */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x00, /* [ ] */
/* 'o' charwidth: 5 */
0x00, /* [ ] */
0x00, /* [ ] */
0x60, /* [ ** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x60, /* [ ** ] */
0x00, /* [ ] */
/* 'p' charwidth: 5 */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0xE0, /* [*** ] */
0x80, /* [* ] */
0x80, /* [* ] */
/* 'q' charwidth: 5 */
0x00, /* [ ] */
0x70, /* [ *** ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x10, /* [ * ] */
0x10, /* [ * ] */
/* 'r' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0xA0, /* [* * ] */
0xC0, /* [** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* 's' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0x60, /* [ ** ] */
0xC0, /* [** ] */
0x20, /* [ * ] */
0xC0, /* [** ] */
0x00, /* [ ] */
/* 't' charwidth: 3 */
0x00, /* [ ] */
0x80, /* [* ] */
0xC0, /* [** ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* 'u' charwidth: 5 */
0x00, /* [ ] */
0x00, /* [ ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x90, /* [* * ] */
0x70, /* [ *** ] */
0x00, /* [ ] */
/* 'v' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0xA0, /* [* * ] */
0xA0, /* [* * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x00, /* [ ] */
/* 'w' charwidth: 6 */
0x00, /* [ ] */
0x00, /* [ ] */
0x50, /* [ * * ] */
0x50, /* [ * * ] */
0x00, /* [ ] */
/* 'x' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0xA0, /* [* * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0xA0, /* [* * ] */
0x00, /* [ ] */
/* 'y' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0xA0, /* [* * ] */
0xA0, /* [* * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0x80, /* [* ] */
/* 'z' charwidth: 4 */
0x00, /* [ ] */
0x00, /* [ ] */
0xE0, /* [*** ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0xE0, /* [*** ] */
0x00, /* [ ] */
/* '{' charwidth: 4 */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
/* '|' charwidth: 2 */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x80, /* [* ] */
0x00, /* [ ] */
/* '}' charwidth: 4 */
0x80, /* [* ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x20, /* [ * ] */
0x40, /* [ * ] */
0x40, /* [ * ] */
0x80, /* [* ] */
/* '~' charwidth: 7 */
0x00, /* [ ] */
0x98, /* [* ** ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00, /* [ ] */
0x00 /* [ ] */
const uint8_t five_dot_width_table[] = {
2, /* ' ' */
2, /* '!' */
4, /* '"' */
8, /* '#' */
4, /* '$' */
8, /* '%' */
6, /* '&' */
2, /* ''' */
3, /* '(' */
3, /* ')' */
6, /* '*' */
6, /* '+' */
3, /* ',' */
4, /* '-' */
2, /* '.' */
4, /* '/' */
5, /* '0' */
3, /* '1' */
5, /* '2' */
5, /* '3' */
5, /* '4' */
4, /* '5' */
5, /* '6' */
4, /* '7' */
5, /* '8' */
5, /* '9' */
2, /* ':' */
3, /* ';' */
4, /* '<' */
5, /* '=' */
4, /* '>' */
4, /* '?' */
8, /* '@' */
6, /* 'A' */
5, /* 'B' */
5, /* 'C' */
5, /* 'D' */
4, /* 'E' */
4, /* 'F' */
5, /* 'G' */
5, /* 'H' */
2, /* 'I' */
5, /* 'J' */
5, /* 'K' */
4, /* 'L' */
6, /* 'M' */
6, /* 'N' */
5, /* 'O' */
5, /* 'P' */
5, /* 'Q' */
5, /* 'R' */
4, /* 'S' */
4, /* 'T' */
5, /* 'U' */
6, /* 'V' */
8, /* 'W' */
6, /* 'X' */
6, /* 'Y' */
4, /* 'Z' */
3, /* '[' */
4, /* '\' */
3, /* ']' */
6, /* '^' */
6, /* '_' */
3, /* '`' */
5, /* 'a' */
5, /* 'b' */
4, /* 'c' */
5, /* 'd' */
4, /* 'e' */
4, /* 'f' */
5, /* 'g' */
5, /* 'h' */
2, /* 'i' */
3, /* 'j' */
5, /* 'k' */
2, /* 'l' */
6, /* 'm' */
5, /* 'n' */
5, /* 'o' */
5, /* 'p' */
5, /* 'q' */
4, /* 'r' */
4, /* 's' */
3, /* 't' */
5, /* 'u' */
4, /* 'v' */
6, /* 'w' */
4, /* 'x' */
4, /* 'y' */
4, /* 'z' */
4, /* '{' */
2, /* '|' */
4, /* '}' */
7 /* '~' */
struct FONT_DEF
uint8_t store_width; /* glyph storage width in bytes */
uint8_t glyph_height; /* glyph height for storage */
uint8_t fixed_width; /* fixed width of glyphs. If zero */
/* then use the width table. */
uint8_t glyph_beg; /* start ascii offset in table */
uint8_t glyph_end; /* end ascii offset in table */
uint8_t glyph_def; /* for undefined glyph */
}fonts={
1, 7, 0, ' ','~','.'
uint8_t glcd_Buffer[GLCD_Y_BYTES][GLCD_X_BYTES];
const uint8_t glcd_MaskArray[8] =
{0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
// Function Prototypes
void glcd_init(int1 mode);
void glcd_pixel(int8 x, int8 y, int1 color);
void glcd_fillScreen(int1 color);
void glcd_writeByte(int1 side, BYTE data);
BYTE glcd_readByte(int1 side);
void glcd_update();
void glcd_Glyph(uint8_t left, uint8_t top, uint8_t width, uint8_t height, uint16_t *glyph, uint8_t store_width);
void glcd_Text(uint8_t left, uint8_t top, char *str);
#ifdef FAST_GLCD
struct
int8 left[512];
int8 right[512];
} displayData;
// Purpose: Initialize the LCD.
// Call before using any other LCD function.
// Inputs: OFF - Turns the LCD off
// ON - Turns the LCD on
// Initialze some pins
output_high(GLCD_RST);
output_low(GLCD_E);
output_low(GLCD_CS1);
output_low(GLCD_CS2);
output_low(GLCD_DI); // Set for instruction
glcd_writeByte(GLCD_LEFT, 0xC0); // Specify first RAM line at the top
glcd_writeByte(GLCD_RIGHT, 0xC0); // of the screen
glcd_writeByte(GLCD_LEFT, 0x40); // Set the column address to 0
glcd_writeByte(GLCD_RIGHT, 0x40);
glcd_writeByte(GLCD_LEFT, 0xB8); // Set the page address to 0
glcd_writeByte(GLCD_RIGHT, 0xB8);
if(mode == ON)
glcd_writeByte(GLCD_LEFT, 0x3F); // Turn the display on
glcd_writeByte(GLCD_RIGHT, 0x3F);
glcd_writeByte(GLCD_LEFT, 0x3E); // Turn the display off
glcd_writeByte(GLCD_RIGHT, 0x3E);
glcd_fillScreen(OFF); // Clear the display
#ifdef FAST_GLCD
glcd_update();
// Purpose: Update the LCD with data from the display arrays
#ifdef FAST_GLCD
void glcd_update()
int8 i, j;
int8 *p1, *p2;
p1 = displayData.left;
p2 = displayData.right;
// Loop through the vertical pages
for(i = 0; i < 8; ++i)
glcd_writeByte(GLCD_LEFT, 0x40); // Set horizontal address to 0
glcd_writeByte(GLCD_LEFT, i | 0xB8); // Set page address
glcd_writeByte(GLCD_RIGHT, i | 0xB8);
output_high(GLCD_DI); // Set for data
// Loop through the horizontal sections
for(j = 0; j < 64; ++j)
glcd_writeByte(GLCD_LEFT, *p1++); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, *p2++); // Turn pixels on or off
void glcd_updateA()
int8 i, j;
int8 *p;
p = glcd_Buffer;
glcd_writeByte(GLCD_LEFT, *p++); // Turn pixels on or off
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: 1) x - the x coordinate of the pixel
// 2) y - the y coordinate of the pixel
// 3) color - ON or OFF
#ifdef FAST_GLCD
int8* p;
int16 temp;
temp = y/8;
temp *= 64;
temp += x;
if(x > 63)
p = displayData.right + temp - 64;
p = displayData.left + temp;
if(color)
bit_set(*p, y%8);
bit_clear(*p, y%8);
#else
BYTE data;
int1 side = GLCD_LEFT; // Stores which chip to use on the LCD
if(x > 63) // Check for first or second display area
x -= 64;
side = GLCD_RIGHT;
bit_clear(x,7); // Clear the MSB. Part of an instruction code
bit_set(x,6); // Set bit 6. Also part of an instruction code
glcd_writeByte(side, x); // Set the horizontal address
glcd_writeByte(side, (y/8 & 0xBF) | 0xB8); // Set the vertical page address
glcd_readByte(side); // Need two reads to get data
data = glcd_readByte(side); // at new address
if(color == ON)
bit_set(data, y%8); // Turn the pixel on
else // or
bit_clear(data, y%8); // turn the pixel off
glcd_writeByte(side, data); // Write the pixel data
// Purpose: Fill the LCD screen with the passed in color
// Inputs: ON - turn all the pixels on
// OFF - turn all the pixels off
#ifdef FAST_GLCD
int8 data;
int8 *p1, *p2;
int16 i;
data = 0xFF * color;
for(i=0; i<512; ++i)
*p1++ = data;
*p2++ = data;
#else
int8 i, j;
glcd_writeByte(GLCD_LEFT, 0b01000000); // Set horizontal address to 0
glcd_writeByte(GLCD_RIGHT, 0b01000000);
glcd_writeByte(GLCD_LEFT, i | 0b10111000);// Set page address
glcd_writeByte(GLCD_RIGHT, i | 0b10111000);
glcd_writeByte(GLCD_LEFT, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, 0xFF*color); // Turn pixels on or off
// Purpose: Write a byte of data to the specified chip
// Inputs: 1) chipSelect - which chip to write the data to
// 2) data - the byte of data to write
if(side) // Choose which side to write to
output_high(GLCD_CS2);
output_high(GLCD_CS1);
output_low(GLCD_RW); // Set for writing
output_d(data); // Put the data on the port
delay_cycles(1);
output_high(GLCD_E); // Pulse the enable pin
delay_cycles(5);
output_low(GLCD_E);
output_low(GLCD_CS1); // Reset the chip select lines
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
BYTE data; // Stores the data read from the LCD
set_tris_d(0xFF); // Set port d to input
output_high(GLCD_RW); // Set for reading
delay_cycles(1);
delay_cycles(4);
data = input_d(); // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
#include "graphics.c"
void glcd_fillscrn(int8 side)
int i,j;
if(side == ON)
glcd_writeByte(GLCD_CS1, 0b01000000); // Set horizontal address to 0
glcd_writeByte(GLCD_CS1, i | 0b10111000); // Set page address
glcd_writeByte(GLCD_CS2, 0b01000000);
glcd_writeByte(GLCD_CS2, i | 0b10111000);
if(side == ON)
glcd_writeByte(GLCD_CS1, 0x00); // Turn pixels on or off
glcd_writeByte(GLCD_CS2, 0x00); // Turn pixels on or off
Writes a glyph("letter") to the display at location x,y
(adapted function from the MJK-code)
Arguments are:
column - x corrdinate of the left part of glyph
row - y coordinate of the top part of glyph
width - size in pixels of the width of the glyph
height - size in pixels of the height of the glyph
glyph - an unsigned char pointer to the glyph pixels
to write assumed to be of length "width"
uint8_t bit_pos;
uint8_t byte_offset;
uint8_t y_bits;
uint8_t remaining_bits;
uint8_t mask;
uint8_t char_mask;
uint8_t x,z;
uint16_t *glyph_scan;
uint8_t glyph_offset;
char tt[16];
int i, j;
bit_pos = top & 0x07; /* get the bit offset into a byte */
glyph_offset = 0; /* start at left side of the glyph rasters */
char_mask = 0x80; /* initial character glyph mask */
for (x = left; x < (left + width); x++)
byte_offset = top >> 3; /* get the byte offset into y direction */
y_bits = height; /* get length in y direction to write */
remaining_bits = 8 - bit_pos; /* number of bits left in byte */
mask = glcd_MaskArray[bit_pos]; /* get mask for this bit */
glyph_scan = glyph + glyph_offset; /* point to base of the glyph */
/* boundary checking here to account for the possibility of */
/* write past the bottom of the screen. */
while((y_bits) && (byte_offset < GLCD_Y_BYTES)) /* while there are bits still to write */
/* check if the character pixel is set or not */
if(*glyph_scan & char_mask)
glcd_Buffer[byte_offset][x] |= mask; /* set image pixel */
//glcd_writeByte(GLCD_CS1,glcd_Buffer[byte_offset][x]);
glcd_Buffer[byte_offset][x] &= ~mask; /* clear the image pixel */
if(glcd_MaskArray[0] & 0x80)
mask >>= 1;
mask <<= 1;
y_bits--;
remaining_bits--;
if(remaining_bits == 0)
/* just crossed over a byte boundry, reset byte counts */
remaining_bits = 8;
byte_offset++;
mask = glcd_MaskArray[0];
/* bump the glyph scan to next raster */
glyph_scan += store_width;
/* shift over to next glyph bit */
char_mask >>= 1;
if(char_mask == 0) /* reset for next byte in raster */
char_mask = 0x80;
glyph_offset++;
Prints the given string at location x,y in the specified font.
Prints each character given via calls to lcd_glyph. The entry string
is null terminated and non 0x20->0x7e characters are ignored.
Arguments are:
left coordinate of left start of string.
top coordinate of top of string.
font font number to use for display (see fonts.h)
str text string to display (null-terminted)
uint8_t x;
uint8_t glyph;
uint8_t width;
uint8_t height;
uint16_t *glyph_ptr;
uint8_t *ptr;
char tt[10];
int16 i;
x=left;
while(*str != 0x00)
glyph = (uint8_t)*str;
/* check to make sure the symbol is a legal one */
/* if not then just replace it with the default character */
if((glyph < fonts.glyph_beg) || (glyph > fonts.glyph_end))
glyph = fonts.glyph_def;
// make zero based index into the font data arrays
glyph -= fonts.glyph_beg;
width = fonts.fixed_width; /* check if it is a fixed width */
if(width == 0)
width=five_dot_width_table[glyph];/* get the variable width instead */
height = fonts.glyph_height;
store_width = fonts.store_width;
ptr = five_dot_glyph_table;
glyph_ptr = (ptr + (uint16_t)glyph * (uint16_t)store_width * (uint16_t)height);
i = *(glyph_ptr+1);
itoa(i,10,tt);
glcd_text57(75,10,tt,1,ON);
delay_ms(200);
/* range check / limit things here */
if(x > GLCD_RIGHTA)
x = GLCD_RIGHTA;
if((x + width) > GLCD_RIGHTA+1)
width = GLCD_RIGHTA - x + 1;
if(top > GLCD_BOTTOM)
top = GLCD_BOTTOM;
if((top + height) > GLCD_BOTTOM+1)
height = GLCD_BOTTOM - top + 1;
glcd_Glyph(x,top,width,height,glyph_ptr,store_width); /* plug symbol into buffer */
x += width; /* move right for next character */
str++; /* point to next character in string */
