Allan
RS 232 Problem |
Posted: Sun Mar 07, 2010 6:56 pm |
Hi Everybody,
I'm on my first RS232 project and I've encountered a strange problem.
I'm using an 18f2321, v 4.104 software, and a pair of National 96176 Driver IC's between two pic's running the same software (except for the debugger code) and a ICD-U64 debugger
#use rs232(uart1, baud = 19200, Enable = EPIN, stream = Remote, DISABLE_INTS)
#use rs232(DEBUGGER, baud = 19200, stream = Debug, DISABLE_INTS)
#INT_RDA
void InputRS232()
extern char c;
c = GetC(Remote);
if (input_state(k_UA)==0)
#USE RS232(Stream=Remote)
putc('U');
#USE RS232(Debugger)
printf("Local Up \r\n");
UpArrow();
if (input_state(k_DA)==0)
putc('D');
printf("Local Down \r\n");
DownArrow();
k_UA and k_DA are Up and Down buttons. I want to send a single character, D or U, to the remote and then use the debugger to print a message to the monitor.
The "Local Up" message displays fine.
The "Local Down" message always displays as "DLocal Down", with the 'D' carried over from the above Putc('D") statement.
Typical output from the monitor:
DLocal Down
DLocal Down
DLoal Down
DLocal Down
Local Up
Local Up
(1) Any idea why the "Down Local" message fails, but "Up Local" always works?
(2) I couldn't find anything on how or when to flush the RS232 comm buffer - Is that necessary?
(3) Any idea why there are letters missing roughly 1 in 10 monitor messages? - I have no other active interrupts running and the speed with which I press the button does not effect the error rate. Changing the Baud rate to 1200 does not help.
Thanks, Al |
Posted: Sun Mar 07, 2010 8:14 pm |
You're using streams. Put the #use rs232() statements above main().
(Just one statement for each stream).
Then use the fprintf(), fgetc(), and fputc() statements, and put the
appropriate stream ID into those statements. See the manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf |
Allan
Posted: Sun Mar 07, 2010 10:20 pm |
Hi PCM programmer,
Back to basics time.
When I use the streams as you suggest I have this program:
Code: | #use rs232(uart1, baud = 19200, Enable = EPIN, stream = Remote, DISABLE_INTS)
Void main(void);
#INT_RDA
void InputRS232()
extern char c;
c = fgetC(Remote);
//#USE RS232(Stream=Remote)
fputc('U', Remote);
//#USE RS232(Debugger)
fprintf(Debug, "Local Up \r\n");
UpArrow();
fputc('D', Remote);
fprintf(Debug, "Local Down \r\n");
DownArrow();
The program sends garbage to the debugger monitor.
When I compromise and use stream names for the Remote function and keep the explicit #USE RS232(Debugger) statements, Like this:
While(1)
fputc('U', Remote);
UpArrow();
fputc('D', Remote,);
DownArrow();
The program works fine - the extra 'D' issue is solved and the errors in the monitor stream are much less frequent (1 in 50)
Is the second program good enough to use, or is there some bug in the first program that I need to find?
Thanks, Al |
