amdatlon
CCP Don't Work with 16F877 ?!?! |
Posted: Sun Mar 07, 2010 5:08 am |
I have a problem please help.
I apologize for bad English!
I'm trying to use CCP Capture module for calculating the period of the rectangular input pulses. Do simulations with Proteus but 16F877 PIC program refuses to work! Never gets a Interrupt from the CCP module.
When I change to 18F458 pic, program works very well.
I have not tried on real PIC 16F877, if it works.
My problem is with Proteus and not know why we receive it.
I tried also the most basic program of "CCS HELP": EX_CCPMP.C
but it does not work with 16F877??
Pattern of connection Proteus are identical, only the PIC is different.
Proteus is 7.6 SP0
CCS is PCWHD v.4.093
I need your help, Thanks in advance:)
This program works with the 18F458 PIC
Code: | #include <18f458.h>
#device *=16 // Pic Model 16F84A
#DEVICE ADC=10
#Fuses HS,NOWDT,NOPROTECT,NOLVP, NOBROWNOUT, NOPUT
#use delay(clock=16000000) // Crystal Oscillator Frequency
#use rs232(baud=15625,parity=N,xmit=PIN_C6, rcv=PIN_C7 ,bits=8,FORCE_SW /* INVERT*/,TIMEOUT=460/*360*/ )
//#include "Function.h"
//#include "string.h"
#include <math.h>
#include <flex_lcd.c>
#ifndef Enable
#define Enable 1
#endif
#ifndef Disable
#define Disable 0
#endif
//*************** TIMER ***************************
//RTC variables
#define XTAL_FREQUENCY 16000000
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 16 );
#define TIMER1_OverflowConst ( (1/TIMER1_FREQUENCY ) * 65536)
#define TIMER1_TicketConst ( (1/TIMER1_FREQUENCY ) )
#byte pA =0xF80 //port a //
#byte pB =0xF81 //b //
#byte pC =0xF82 //c //
#byte pD =0xF83 //d // usb port 8 bits parallel
#byte pE =0xF84 //port e //
#Define SetConfigPortA 0//100011 //33 100001
#Define SetConfigPortB 0//16//16//16
#Define SetConfigPortC 0//bx 00000011
#Define SetConfigPortD 0
#Define SetConfigPortE 0
#define TEST_LED pin_c5
//globals
static int1 fHit = 0;
static int nHits = 1;
int16 timeC = 0, timeL = 0;
//measure the time from rising egdes then process
#int_ccp1
void isr_ext(){
output_low(TEST_LED);
output_high(TEST_LED);
if(nHits==1){
timeL = ccp_1;
nHits=2;
else if(nHits==2){
timeC = CCP_1;//get ccp value
fHit=1; //flag for processing
disable_interrupts(GLOBAL);//disable until processed
nHits=1;//reset nHits to start over
}//isr
VOID MAIN(void)
int8 i = 0;
int16 period = 0, freq = 0;
//setup timer1 to measure pulses
SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_1);
#define DIVIDER 1
//setup ccp1 for interrupt of pulse measurement
CLEAR_INTERRUPT(INT_CCP1);
SETUP_CCP1(CCP_CAPTURE_RE);
enable_interrupts(INT_CCP1);
delay_ms(10);
printf(lcd_putc,"\fstarted...");
while(1){
if(fHit){
printf(lcd_putc,"\fperiod:%lu us",timeC-timeL);
fHit = 0;
}//if
delay_ms(1);
And this does not work with the 16F877 PIC
Code: | #include <16F877.h>
#ifndef ON
#define ON 1
#endif
#ifndef OFF
#define OFF 0
#endif
//RTC variables
#byte pA =5 //port a //
#byte pB =6 //b //
#byte pC =7 //c //
#byte pD =8 //d // usb port 8 bits parallel
#byte pE =9 //port e //
#Define SetConfigPortB 16
#bit SpeedPulse=pB.5
#bit pinB0=pB.0
//globals
#int_ccp1
void isr_ext(){
if(nHits==1){
timeL = ccp_1;
nHits=2;
else if(nHits==2){
}//isr
VOID MAIN(void)
int8 i = 0;
#define DIVIDER 1
delay_ms(10);
while(1){
if(fHit){
//printf("\r\nPeriod:%lu",timeC-timeL);
fHit = 0;//processed hit
}//if
//disable_interrupts(GLOBAL);
delay_ms(1);
}//while
Posted: Sun Mar 07, 2010 1:30 pm |
Capture mode definitely works with the 16F877, and probably works in
your version. It may be a Proteus problem. |
amdatlon
Posted: Sun Mar 07, 2010 3:23 pm |
And I know that should work with PIC 16f877, but now I do not understand what was happening.
I changed the version of Proteus, but no change.
Will change and version of CCS , to see what happens.
I think the scheme is good, because with 18f458 works great. |
