meereck
Simple source code = Erratic behaviour |
Posted: Sun Mar 07, 2010 9:17 am |
Hello guys,
I created a simple application which measures input frequency+duty cycle and it outputs the same frequency but modified duty cycle according to the ADC reading (it extends the duty cycle).
The problem is that it occasionally prints garbage, stops to work, restarts.
I have tried different crystals (HS, H4), a microcontroller with/without TinyBootloader. The problem is not caused by power supply either.
Compiler v4.104
Does anybody have a clue?
Thanks in advance
#include <18F1220.h>
#device adc=8
//#device HIGH_INTS=true
#FUSES HS
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOEBTR //Memory protected from table reads
#FUSES NOEBTRB //Boot block protected from table reads
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOCPB //Boot Block Code Protected
#use rs232(baud=115200,errors,parity=N,UART1,bits=8)
#define MAX_FLASH getenv("PROGRAM_MEMORY")
#define LOADER_SIZE 0xFF //tinybld size + a bit more (200 bytes is enough)
#build(reset=0x0000:0x0007)
#org MAX_FLASH-LOADER_SIZE , MAX_FLASH-1 {}//void boot_loader(void) {}
#use fast_io(a)
#use fast_io(b)
#define trisa 0b00000001
#define trisb 0b00011000
#define PWM_OUT PIN_A2
#define DEBUG 1
unsigned int8 PercentToAdd=0;
int8 SecondTimerFlag=false;
int8 DetectRising=0;
unsigned int16 StartTime=0;
unsigned int16 AddedDuty=0;
unsigned int16 Period=0;
unsigned int16 Duty=0;
#int_TIMER0
void TIMER0_isr(void)
SecondTimerFlag=true;
#int_TIMER3 //FAST
void TIMER3_isr(void)
output_high(PWM_OUT);
disable_interrupts(int_timer3);
#int_CCP1
void ccp()
unsigned int16 tmr3val,ccpval;
ccpval=CCP_1;
if(!DetectRising)
{//falling
output_low(PWM_OUT);
Period=ccpval-StartTime;
StartTime=ccpval;
DetectRising=1;
setup_ccp1(CCP_CAPTURE_RE);
Duty=ccpval-StartTime;
DetectRising=0;
setup_ccp1(CCP_CAPTURE_FE);
if(PercentToAdd<=3)
tmr3val=Period-Duty;
AddedDuty=((unsigned int32)tmr3val*PercentToAdd)/100L;
set_timer3(-AddedDuty);
clear_interrupt(int_timer3);
enable_interrupts(int_timer3);
#zero_ram
unsigned int8 adcval;
setup_wdt(WDT_OFF);
set_tris_a(trisa);
set_tris_b(trisb);
port_b_pullups(TRUE);
setup_adc_ports(sAN0|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_4);
set_adc_channel(0);
if(DEBUG)printf("init\n");
delay_ms(10);
setup_timer_0(T0_INTERNAL|T0_DIV_64);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
setup_timer_2(T2_DIV_BY_16,250,15);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_4);
enable_interrupts(int_ccp1);
enable_interrupts(int_timer0);
enable_interrupts(global);
if(SecondTimerFlag)
adcval=read_adc();
PercentToAdd=((unsigned int16)adcval*100L)/256;
if(DEBUG)printf("%%%u T%lu dut%lu tmr%lu\n",PercentToAdd,Period,Duty,AddedDuty);
Posted: Sun Mar 07, 2010 1:13 pm |
Quote: |
The problem is that it occasionally prints garbage, stops to work, restarts |
Consider these possible problems:
Hardware:
1. Improper MCLR circuit.
2. No bypass capacitors (100 nF, ceramic) on the Vdd pins.
3. Poorly regulated power supply.
4. Incorrect crystal circuit.
5. Poor solder joints (cracked, intermittent connections).
One quick way to check the hardware is to use a factory-built eval board
rather than your own breadboard. If the problem goes away, there is
likely something wrong with your breadboard.
Software:
1. Enabling GLOBAL interrupts while inside an #int_xxx routine.
2. Enabling the XINST fuse in an 18F PIC.
3. Writing past the end of an array, thus over-writing other variables.
4. Watchdog timer enabled, but restart_wdt() is not called often enough.
One quick way to find if it's a software problem is to start commenting
out parts of your code and see if the problem goes away. Disable
interrupts. Comment out any "weird" things that you're doing, such as
#build, High Ints, FAST ints, etc. |
meereck
Posted: Sun Mar 07, 2010 1:37 pm |
thanks for the response.
I am sure this is not HW related, I have tried different crystal oscillators, MCLR is disabled,
>>Comment out any "weird" things that you're doing, such as #build, High ints, FAST ints, etc.
I have already tried those.
>>XINST fuse
It is not possible to use "#fuses NOXINST" keyword when using PIC18F1220.
>>WDT
The watchdog is also disabled.
I am going to comment out some parts of the source code tomorrow. Anyway, the source code is very short - there is nothing which would cause those troubles (e.g. there are no arrays at all...). I highly suspect there is something wrong with the compiler.
I am also going to convert the project to, say, PIC18F2420.
However, can anyone replicate the issue?
Cheers |
meereck
Sorted out |
Posted: Mon Mar 08, 2010 9:07 am |
I have changed the PIC to 18F2420 and problem is sorted out. |
Posted: Mon Mar 08, 2010 9:43 am |
Obvious thing. Revision B1 silicon.
Look at the errata sheet.
meereck
Posted: Mon Mar 08, 2010 9:51 am |
Ttelmah wrote: | Obvious thing. Revision B1 silicon.
omg, piece of crap.
thanks |
