Water Level Sensor
faizal117
Water Level Sensor
PostPosted: Sat Mar 06, 2010 2:29 am     Reply with quote
I want to ask about the water level sensor..
what type of the sensor is suitable for water level measurement?
thank you Smile
hayee
PostPosted: Sat Mar 06, 2010 3:29 am     Reply with quote
You can develop your own simple water level sensor at home, if no special type of sensor is required in your scheme. I can give you an idea how to make this and connect it to microcontroller but how can I upload a picture in the post?
necati
w l
PostPosted: Sat Mar 06, 2010 3:47 am     Reply with quote
http://njhurst.com/electronics/watersensor/
husam
PostPosted: Sat Mar 06, 2010 11:13 am     Reply with quote
hi ,
You can use ultrasonic sensor, check this site
http://www.sparkfun.com/commerce/advanced_search_result.php?keywords=ultrasonic&search_section=products
PostPosted: Sat Mar 06, 2010 1:27 pm     Reply with quote
There are as many different types of water level sensor, as days in a month.
What is best, depends on a suite of factors:
Water in a tank, or open.
Likely range of movement.
Environment.
Accuracy needed.
Speed.
Flow rates, and likely turbulence.
etc...
I have used systems ranging from simple floats, with a cord operating a potentiometer, through versions with linear optical scales, onto capacitive versions (you can get fully sealed versions of the unit mentioned by an earlier poster), ultrasonic, laser reflection, pressure sensors in a tube, etc., etc..
You need to specify the conditions involved to get any real idea of what can be done...
faizal117
PostPosted: Sun Mar 07, 2010 7:49 am     Reply with quote
hayee
PostPosted: Sat Mar 06, 2010 3:29 am Post subject:
thank you for your information hayee...sure u can give your oppinion for my problem...you can send to my email unikl_bmi@yahoo.com and thank you once again Smile have a nice day
ALPL
Re: Water Level Sensor
PostPosted: Sun Mar 07, 2010 11:33 am     Reply with quote
Very simple yet reliable to use is a CD4093-based AD-oscillator/detector-circuit with 2 probes (e.g. metal-wires) installed in a tank, etc. When the liquid level touches both probes one of the CD4093-outputs goes HIGH and switches e.g. a transistor or an opto-coupler which turns ON/OFF a pump, etc. The schematic can easily be found in the internet. Just enter "Water level sensor" and can easily be built.
faizal117
PostPosted: Mon Mar 08, 2010 7:06 am     Reply with quote
Thank you everyone... Smile
