need help about timer1 and interrupts for 18F452
Scythe
PostPosted: Fri Mar 05, 2010 5:08 pm     Reply with quote
------edit--------
PostPosted: Fri Mar 05, 2010 5:41 pm     Reply with quote
Here is a sample program for Timer1 interrupts.
http://www.ccsinfo.com/forum/viewtopic.php?t=25824&start=7
Also, you need to add the HS fuse to your #fuses statements.
HS is used with a 20 MHz crystal.
