2 x rs232 16f877a
makoo
2 x rs232 16f877a
PostPosted: Thu Mar 04, 2010 5:29 pm     Reply with quote
hi there,
I have a rs232 sensor connect to the pic's hardware usart pins c6/c7. I have used an interrupt to get the data when it is being sent. This is then forwarded to the computer via a software usart on pins E0/E1. I used the interrupt as the pic does other stuff which need a constant loop for it to work.
The pic perfectly interrupt and get the reading and send it to the computer, but I want to send commands from the computer to the pic, to perfom a tasks.
I used this code for the sensor: ( I got the interrupt code from the examples in the CCS info folder.) (Code is in a while loop in the main)
while(bkbhit){
       putc( bgetc(),PC );}
so i used this code for the pc: (code is in a while loop in the main)
while(kbhit (PC))(
     cget = fgetc(PC)
       if (cget=='g')
         output_high(PIN_B2);
But when I send a 'g' from hyperterminal, nothing happens. Do I need to set another interrupt? How do I go about making the command from the computer to work?
Thanks in advance for your help.
makoo
PostPosted: Thu Mar 04, 2010 6:15 pm     Reply with quote
while(kbhit (PC)) {
Change this to
while(1) {
The fgetc() function has the kbhit included in it.
makoo
PostPosted: Fri Mar 05, 2010 2:32 am     Reply with quote
i have a while loop in the main already... can i do this?
while (True) --- already in the code...
(if loops)
  delay_ms(500); //  led delay
while(1) {  --- adding this will it work??
cget = fgetc(PC)
       if (cget=='g')
thanks again!
makoo
PostPosted: Fri Mar 05, 2010 2:43 am     Reply with quote
I didn't know that you had an outer loop. Is that all the code in the loop
or is it just code fragments ?
Post the complete code in those two while() loops.
