Programming PIC16F87X as 10 bit ADC and reading it serially
Goto page 1, 2  Next
yousafzai82
View user's profile Send private message AIM Address Yahoo Messenger ICQ Number
PostPosted: Thu Mar 04, 2010 2:18 am     Reply with quote
Hello everyone....
I want to programme pic16f877 as 10 bit adc and read it serially such that it can be interfaced with a Mobile or Modem to send the data. The program should send AT commands for SMS then the Value V shown in the program below. Someone please suggest modification. It is urgent..
#include<16F877.h>
#device ADC=10
#fuses HS,NOWDT
#use delay(clock=10000000)
#use re232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=RS232,bits=8)
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
int16 value,value1,h,V,M;
void main(){
setup_adc( ADC_CLOCK_INTERNAL );
setup_adc_ports( ALL_ANALOG );
set_adc_channel(1);
while(1){
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
delay_ms( 3000000);
value = read_adc();
h=0.0078201*value;
if(h<=4)
M=2*acos((4-h)/4);
V=10*(16*M/2-16*sin(M/2)+h*4*sin(M/2));
M=2*acos((h-4)/4);
V=10*(16*3.14159*(1-M/(2*3.14159))+h*4*sin(M/2)-16*sin(M/2));
printf("%f/n/r",(float)V);
zaky
yousafzai82
PostPosted: Thu Mar 04, 2010 3:10 am     Reply with quote
Someone please help me.. it is urgent....
zaky
yousafzai82
PostPosted: Thu Mar 04, 2010 4:31 am     Reply with quote
Reply please..........
zaky
PostPosted: Thu Mar 04, 2010 4:55 am     Reply with quote
Comments in the code:
   while(1) {
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      delay_ms( 3000000);
      //If these delays worked, it'd be 8.3 hours, before you got here
      //For debugging, stick the delays after the transmission, so you can
      //see what happens.....
      //However, RTFM. What is the maximum value you can use in a
      //delay?......
      value = read_adc();
      h=0.0078201*value; //h=0 to 8 _integer_
      if(h<=4) {
         M=2*acos((4-h)/4);
         //If incoming value < 512
         //Just five possible values for 'M'. 1.5707, 1.318, 1.047, 0.7227, 0
         //Is this what you really want/mean?....
         //Again only five possible output values fo the whole 512 inputs
     else {
        M=2*acos((h-4)/4);
It'd be much simplr, if you posted what you actually expect your arithmetic to actually do?.
You seem to be forgetting at least one thing - h -is an integer, 0 to 8. with only nine possible output values for the arithmetic, it'd be much simpler just to have these stored and output them from a lookup table....
Read up in the data sheet on the recommended ADC clock. ADC_CLOCK_INTERNAL, is _not_ what should be used....
PostPosted: Thu Mar 04, 2010 6:57 am     Reply with quote
#include<16F877.h>
#device ADC=10
#fuses HS,NOWDT
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
float value,value1,h,V,M;
void main(){
set_adc_channel(1);
while(1){
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   delay_ms( 300000);
   value = read_adc();
   h=0.0078201*value;
   if(h<=4)
      M=2*acos((4-h)/4);
      M=2*acos((h-4)/4);
I think it should be okay now with float. I used Turbo C to apply the same formula and it was working fine. These are to find out the volume of a oil in a cylinder.
My main problem is how edit this program to send AT commands followed by value V through SMS using a mobile ?
yousafzai82
PostPosted: Thu Mar 04, 2010 7:05 am     Reply with quote
Sorry
I posted the above comment without login...
Also check the commands for serial communication whether they are alright..
Zaky
zaky
yousafzai82
PostPosted: Fri Mar 05, 2010 2:19 am     Reply with quote
Hi everyone
I am getting the following error messages when i run it. Someone please confirm is it the right way to send AT commands followed by the adc result on a mobile phone.
#include<16F877.h>
#device ADC=10
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,PUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=RS232,bits=8)
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
//#include "C:\Program files\PICC\Devices\16f877.h"
#Byte PortA=0x05
#Byte PortB=0x06
#use fast_io(A)
#use fast_io(B)
#Define Nop #Asm Nop #EndAsm
int16 value;
float h,V,M;
void main(){
set_adc_channel(1);
while(1){
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   value = read_adc();
   h=0.0078201*value;
   if(h<=4)
      M=2*acos((4-h)/4);
      M=2*acos((h-4)/4);
     send_SMS();
void send_SMS(void)
  printf("AT\r\n");
  delay_ms(5000);
  printf("at+cmgf=1\r\n");
  delay_ms(5000);
  printf("at+cmgs=\"+4478XXXXXXXX\"\r\n");
  delay_ms(5000);
  putc(0x1A);
  delay_ms(5000);
   SET_TRIS_A( 0b10000110 );
   SET_TRIS_B( 0b00000101 );   delay_ms(1);
   send_SMS();
         // Toggle led
         PORTA ^= 1;
         // Simple delay
After compiling it I am getting the following error messages:
Error 12 Undefined identifier Send_SMS()
Error 117 Improper use of a function identifier in the line ""printf("AT\r\n");
Error31 line70 identifier is already used in this scope.
zaky
PostPosted: Fri Mar 05, 2010 3:20 am     Reply with quote
You have two 'main' functions defined. Won't work.
The first doesn't have a closing bracket, so the whole bracketting 'goes to pot....
Basic syntax errors.
yousafzai82
PostPosted: Fri Mar 05, 2010 4:33 am     Reply with quote
Thanks Ttelmah
#include<16F877.h>
#device ADC=10
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
#Byte PortA=0x05
#Byte PortB=0x06
#use fast_io(A)
#use fast_io(B)
int16 value;
float h,V,M;
void main(){
set_adc_channel(1);
while(1){
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   delay_ms( 30000);
   value = read_adc();
   h=0.0078201*value;
   if(h<=4)
      M=2*acos((4-h)/4);
      M=2*acos((h-4)/4);
     send_SMS();
void send_SMS(void)
  printf("AT\r\n");
  delay_ms(5000);
  delay_ms(5000);
  delay_ms(5000);
  putc(0x1A);
  delay_ms(5000);
   send_SMS();
         // Toggle led
         PORTA ^= 1;
         // Simple delay
Now I am getting the error message
"Improper use of function identifier" at line printf("AT\r\n");
and undefined identifier at line "send_SMS();"
zaky
bungee-
PostPosted: Fri Mar 05, 2010 6:22 am     Reply with quote
Again you have TWO main() functions. This will not work, then you have some statements outside the {} brackets.
Then in send_sms function you are using variables, that are not declared there...
yousafzai82
PostPosted: Fri Mar 05, 2010 7:28 am     Reply with quote
Someone please remove the errors... I am really stuck...
zaky
bungee-
PostPosted: Fri Mar 05, 2010 10:44 am     Reply with quote
We certainly could do that, but errors there are so trivial and by doing so you would not learn anything.
But I'll give you a hint structure ....
#FUSES
int some_global_variable;
void some_function1()
   do_something();
void other_function(int pass_variable)
   printf(" %X \r\n",pass_variable);
        int Local_variable;
   do_setup();
      do_some_operations();
      some_function1();
      other_function(35);
Observe where I declared functions and where I placed function main(). Global variable can be used by all functions, where Locab_variable can be used only in function main.
yousafzai82
PostPosted: Sun Mar 07, 2010 11:58 pm     Reply with quote
#include<16F877.h>
#device ADC=10
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
#Byte PortA=0x05
#Byte PortB=0x06
#use fast_io(A)
#use fast_io(B)
int16 value;
float h,V,M;
void send_SMS(void)
printf("AT\r\n");
delay_ms(5000);
delay_ms(5000);
printf("at+cmgs=\"+923469400983\"\r\n");
delay_ms(5000);
putc(0x1A);
delay_ms(5000);
void main(){
set_adc_channel(1);
while(1){
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
value = read_adc();
h=0.0078201*value;
if(h<=4)
M=2*acos((4-h)/4);
M=2*acos((h-4)/4);
send_SMS();
Now I am getting the error message Line94(0,1) Out of ROM, a segment or the program is too large sin.
zaky
yousafzai82
PostPosted: Mon Mar 08, 2010 2:35 am     Reply with quote
Someone tell me how to use #separate functions or use some other means to remove the above error....
zaky
hayee
PostPosted: Mon Mar 08, 2010 4:27 am     Reply with quote
I compiled your program and it didn't show any error.
Why it is showing an error at your side?
Goto page 1, 2  Next
Page 1 of 2
