pic18f67j10
yahyooh
pic18f67j10
PostPosted: Wed Mar 03, 2010 2:32 am     Reply with quote
Can anybody tell me way. I see an Error during compiling while I use pic18f67j10 in
#use delay(clock=10000000)
I tried many times but no response.
PostPosted: Wed Mar 03, 2010 3:26 pm     Reply with quote
The program shown below compiles with no errors with compiler vs. 4.105:
#include <18F67J10.h>
#fuses HS,NOWDT
yahyooh
PostPosted: Thu Mar 04, 2010 12:03 pm     Reply with quote
No I am sure of it. I tried many times. The Error message says that clock is out of range. I tried another clock frequency but the same appears to me & for knowledge I tried to write the program in USB master Kit but it doesn't work. Please help me.
Thanx for your responding.
PostPosted: Thu Mar 04, 2010 12:06 pm     Reply with quote
What is your compiler version ?
yahyooh
PostPosted: Thu Mar 04, 2010 12:40 pm     Reply with quote
my ver. is 4.105 can you find a sulotion???
thanx a lot Very Happy
PostPosted: Thu Mar 04, 2010 12:50 pm     Reply with quote
I compiled the test program that I posted above with vs. 4.105
and I don't get any clock speed errors:
CS PCH C Compiler, Version 4.105, xxxxx 04-Mar-10 10:50
Filename: C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.lst
ROM used: 26 bytes (0%)
Largest free fragment is 65528
RAM used: 4 (0%) at main() level
4 (0%) worst case
Stack: 0 locations
Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "PCH_Test.c" +DF +LN +T +A +M +Z +Y=9 +EA
>>> Warning 203 "PCH_Test.c" Line 9(1,1): Condition always TRUE
Memory usage: ROM=0% RAM=0% - 0%
0 Errors, 1 Warnings.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Thu Mar 04 10:50:07 2010
yahyooh
PostPosted: Thu Mar 04, 2010 12:53 pm     Reply with quote
ok then i will test again & i will contact you for any news
thanx alot Very Happy
