interrupt problem
koray_duran
interrupt problem
PostPosted: Sat Feb 27, 2010 8:06 am     Reply with quote
I have an error as interrupts disabled during call to prevent re-entrancy @DIV88. Do you have any idea what is this ???
Here is my code :
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_A0, rcv=PIN_A1, stream=PC)
// Defines the destination's RS485 ID
#define  RS485_DEST_ID        0x11
// Defines the device's RS485 ID
#define  RS485_ID             0x7F
#define  RS485_USE_EXT_INT    TRUE
#include <rs485.c>
int8 buffer[40];
int8 next_in  = 0;
int8 next_out = 0;
#INT_RDA
void serial_isr()
   int8 t;
   buffer[next_in] = fgetc(PC);
   t = next_in;
   next_in = (next_in+1) % sizeof(buffer);
   if(next_in == next_out)
      next_in=t;        // Buffer full !!
#define bkbhit (next_in != next_out)
int8 bgetc()
   int8 c;
   while(!bkbhit);
   c = buffer[next_out];
   next_out = (next_out+1) % sizeof(buffer);
   return c;
   int8 i, msg[32];
   enable_interrupts(INT_RDA);
   rs485_init();
   for(;;) {
      if(rs485_get_message(msg, FALSE)) {
         for(i=0; i<msg[1]; ++i)
            fputc(msg[i+2], PC);
      for(i=0; bkbhit && i<sizeof(msg); ++i)
         msg[i] = bgetc();
      if(i > 0) {
         rs485_wait_for_bus(FALSE);
         while(!rs485_send_message(RS485_DEST_ID, i, msg)) {
            delay_ms(RS485_ID);
dyeatman
Try a search
PostPosted: Sat Feb 27, 2010 9:16 am     Reply with quote
This has been asked MANY times before. Why don't you try searching before asking?
Search on:
Then select the option Search for All Terms. You will find a lot of hits and information.
Google and Forum Search are some of your best tools!!!!
PostPosted: Sat Feb 27, 2010 10:11 am     Reply with quote
The other comment, is to change the buffer size to a binary multiple. 32, 64 etc..
The problem here is that if you use a 'non binary' size, the compiler has to calculate the modulus funstion, by performing a division. This takes 116 machine cycles, and results in the interrupt disabled message, if the 8 bit division is used elsewhere in the code.
However use a binary size, and the same function can be performed by a bitwise '&'. Only takes a couple of mchine cycles!.....
If you look at the CCS examples, they use a binary multiple size. There really ought to be a warning, to keep to this.....
andrewg
PostPosted: Sat Feb 27, 2010 8:49 pm     Reply with quote
I would have written:
if (++next_in == sizeof(buffer)) next_in = 0;
if (next_in == next_out) next_in = t;
Andrew
John P
PostPosted: Sat Feb 27, 2010 11:14 pm     Reply with quote
And I would have written:
int8 buffer[32];
bit_clear(++next_in, 5);        // If it hits 32, reset to 0
PostPosted: Sun Feb 28, 2010 3:28 am     Reply with quote
Yes.
Andrewg's solution, has the advantage of working for any buffer size.
It is well worth looking at the .lst
For the original solution, with a buffer size of 40, you get:
....................    next_in = (next_in+1) % sizeof(buffer);
00E2:  MOVLW  01
00E4:  ADDWF  42,W
00E6:  MOVWF  49
00E8:  MOVWF  4A
00EA:  MOVLW  28
00EC:  MOVWF  4B
00EE:  BRA    00A2
00F0:  MOVFF  00,42
//and at A2 (the actual division)
00A2:  MOVF   4B,W
00A4:  CLRF   01
00A6:  SUBWF  4A,W
00A8:  BC    00B0
00AA:  MOVFF  4A,00
00AE:  BRA    00C8
00B0:  CLRF   00
00B2:  MOVLW  08
00B4:  MOVWF  4C
00B6:  RLCF   4A,F
00B8:  RLCF   00,F
00BA:  MOVF   4B,W
00BC:  SUBWF  00,W
00BE:  BTFSC  FD8.0
00C0:  MOVWF  00
00C2:  RLCF   01,F
00C4:  DECFSZ 4C,F
00C6:  BRA    00B6
00C8:  GOTO   00F0 (RETURN)
with the central bit of this looping 8 times...
For the original code, with a binary buffer size, this reduces to:
00B8:  MOVLW  01
00BA:  ADDWF  3A,W
00BC:  ANDLW  1F
00BE:  MOVWF  3A
Just four instructions.
Andrewg's version, takes one more instruction than this, but works for any buffer size.
John P's version, takes just two instructions, but is again limited to binary buffer sizes.
So, for a binary buffer size, you can beat the compiler's default solution, by going with John P's solution. For a non binary size, switching to Andrewg's solution, costs just one instruction (beating the default solution by 111 instructions). Both avoid using divisions.
You will find all of this has been covered many times in the past....
koray_duran
PostPosted: Sun Feb 28, 2010 8:57 am     Reply with quote
Thanks!!!! I've solved the warning. =)
But still my device doesn't work!!! It seems I will work on this for a while.
