I have 12F508 which is generating 2 frequencies with different duty cycle. I have two inputs on pins GP4 and GP5. For the different configurations on inputs, I must output different frequency on the output. So I need a code how to set up interrupt routine on pin change (in this routine I will read the inputs and determine which frequency to generate).
Thank you !
Best regards,
Ivailo
Posted: Sun Feb 28, 2010 12:38 am
The 12F508 doesn't have any interrupts. Download the data sheet
and search for the word "interrupt". You won't find it.
http://ww1.microchip.com/downloads/en/DeviceDoc/41236E.pdf
So if you want to check those pins for user input, you will have
to poll them (i.e., read them at a periodic interval).
