But I have the following question how do I clear/set the 9 bit of transmission TX9D in the TXSTA Register, and how do I read the 9 bit of reception RX9D in the RCSTA Register
For a moment I was planning to use the putc() and readc() functions but the manual says it works with 8 bits. Maybe it changes automatically when you declare the 9 bits and you could transmit a 16 bit register (it will only transmit the first 9 bits)
Thanks for your help. _________________ Viotronics Inc.
Intelligent Communication & Control Systems
http://www.viotronics.com
