Code for getch()
ac34856
Code for getch()
PostPosted: Tue Feb 23, 2010 12:56 pm     Reply with quote
I'd like to modify the code for getc() or getch() or getchar().
Is this defined somewhere, I cant find it ?
PostPosted: Tue Feb 23, 2010 1:06 pm     Reply with quote
There is no C source code for it. To see the ASM code, make a test
program, compile it, and look at the .LST file. This thread has an
example of how to do that:
http://www.ccsinfo.com/forum/viewtopic.php?t=38623
PostPosted: Tue Feb 23, 2010 3:49 pm     Reply with quote
You also, don't have to.
Just write your own. Call it something like 'my_getc', and use this. This is what you do for anything like buffered I/O. The standard code, is not loaded, unless used, so don't worry about it.....
On the latest compiler, you can tell the code to use separate routines, avoiding the need to use a different name.
PostPosted: Tue Feb 23, 2010 3:58 pm     Reply with quote
This thread has an example of a my_getc() function:
http://www.ccsinfo.com/forum/viewtopic.php?t=26631
