newbie question; configuring a pin
PostPosted: Mon Feb 22, 2010 4:30 pm     Reply with quote
Hey I have a quick one. I'm using a 16f684 and I'm trying to configure pin RA5 as an i/o. I see the table for setting the correct bit to change this pin, but I'm not sure how to do so in the compiler. Most tutorials I've seen for configuring pins use fuses, but I'm trying to find out how to figure out which fuse sets the bit correctly. The fuses in the .h file don't reference which bits they are manipulating, so there must be something I'm missing. I'm still fairly new at reading data sheets. Thanks!!
I would post the link for the data sheet, but it wont let me because I'm not registered.
PostPosted: Mon Feb 22, 2010 4:36 pm     Reply with quote
Never mind, I figured it out. The datasheet actually labels the fuses as well. I had to set the INTRC_IO fuse. (internal clock i/o)
