theasus
DS1302 problem working with 18f4550 |
Posted: Sun Feb 21, 2010 4:03 am |
I can use DS1302 with PIC16F877A. But I can't use DS1302 with 184550.
I couldn't understand the problem. Nothing appears on LCD.
Here is my code:
#include <18F4550.h>
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOMCLR //Master Clear pin enabled
#define use_portd_lcd TRUE
#include <lcd.c>
#include <DS1302.c>
byte hour,minute,second;
setup_adc(ADC_OFF);
setup_vref(FALSE);
lcd_init();
rtc_init();
rtc_set_datetime(21,02,10,6,12,52);
while(true)
rtc_get_time(hour,minute,second);
printf(lcd_putc,"\nTime:%02d:%02d:%02d",hour,minute,second);
