PIC A/D
Daniel_Follmer
PIC A/D
PostPosted: Sat Feb 20, 2010 4:54 pm     Reply with quote
I want to configure only one A/D channel using PIC16F716 but it is not possible.
The options offered by the compiler are below:
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS            7   // None
#define ALL_ANALOG            0   // A0 A1 A2 A3
#define AN0_AN1_AN2_VSS_VREF  1   // A0 A1 A2 VRefh=A3
#define AN0_AN1_AN3           4   // A0 A1 A3
#define AN0_AN1_VSS_VREF      5   // A0 A1 VRefh=A3
#define ANALOG_RA3_REF   1     //!old only provided for compatibility
#define RA0_RA1_RA3_ANALOG   4    //!old only provided for compatibility
#define RA0_RA1_ANALOG_RA3_REF 5 //!old only provided for compatibility
Could someone help me?
Thank you
PostPosted: Sat Feb 20, 2010 11:50 pm     Reply with quote
It's not the compiler. It's the PIC. Download the 16F716 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/41206B.pdf
Look in this section:
REGISTER 7-2: ADCON1: A/D CONTROL REGISTER 1
Look at the table for the PCFG bits.
PCFG<2:0>
It shows 6 possible configurations of A/D pins. That's all you can do.
You can't select individual Analog pins with this PIC.
