getch() problem
pic_pro2010
getch() problem
PostPosted: Sat Feb 20, 2010 4:38 am     Reply with quote
Here is the code I am trying to compile:
char menu(void);
    switch (menu()) {
      case '1': {
         output_bit(PIN_A0,1);
         output_bit(PIN_A0,0);
      case '2': {
         output_bit(PIN_A1,1);
         output_bit(PIN_A1,0);
      case '3': {
         output_bit(PIN_A2,1);
         output_bit(PIN_A2,0);
      default: {
///////User Selection Menu//////////////////////////////
line 54: char menu(void)
char ch;
printf ("\n\r Press A to turn LED on RA0 .......");
printf ("\n\r Press B to turn LED on RA1 .......");
printf ("\n\r Press C to turn LED on RA2 .......");
ch = getc();   //wait for and get serial character
//delay_ms(100);
return ch;
And these are the error messages I am getting:
>>> Warning 203 "pic18f4523ledo_p.c" Line 13(1,1): Condition always TRUE
*** Error 51 "pic18f4523ledo_p.c" Line 54(1,5): A numeric expression must appear here
*** Error 127 "pic18f4523ledo_p.c" Line 62(10,16): Return value not allowed in void function
*** Error 79 "pic18f4523ledo_p.c" Line 66(57,58): Expect }
3 Errors, 1 Warnings.
I am lost. What am I missing here?
PostPosted: Sat Feb 20, 2010 2:12 pm     Reply with quote
Start by getting rid of the brackets round the case sections....
PostPosted: Sat Feb 20, 2010 4:40 pm     Reply with quote
In addition to that, I think you're missing a closing brace at the end of main().
