moving message help needed
joshinjoy
PostPosted: Thu Feb 18, 2010 10:53 pm     Reply with quote
I am in project of building moving message display.
One character is 16x16 led matrix there are total 6 characters.
So there are 16 rows and 96 columns.
The rows are connected with two 74ls595 shift registers and ULN2803
transistor array. Columns are connected to 74ls595 shift register.
I used 18f252. I used hardware MSSP SPI interface to 74ls595 .
My program works as this:
1st all the shift register loaded with data and that row is switched on.
Then again all the shift registers are loaded and second line is switched on.
This repeats.
My problem is the blinking of led is very much. How can I overcome it ?
I am linking my program. Anyone please help me.
#include <C:\Program Files\PICC\Devices\18f252.h>
#device adc=8
#FUSES NOWDT                  //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES WRTC                     //configuration registers write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use delay(clock=40000000)
#define   down_dat   PIN_B0
#define   down_clk   PIN_B2
#define   down_cs    PIN_B1
#define   shift_cs    PIN_C2
void down_send(int1 dat);
int16 modify(int16 value,int16 v_);
int16 load(int16 lding,int16 cur);
void nxt_char(void);
void select(void);
void nxt_ch2(void);
const int16 and[] = {
0b1000000000000000,0b0100000000000000,0b0010000000000000,
0b0001000000000000,0b0000100000000000,0b0000010000000000,
0b0000001000000000,0b0000000100000000,0b0000000010000000,
0b0000000001000000,0b0000000000100000,0b0000000000010000,
0b0000000000001000,0b0000000000000100,0b0000000000000010,
0b0000000000000001
//table of small letters
const int16 tabel_sm[] = {
0x001c,
0b0000000000000000,0b0000000000000000,0b0000000000000000,
0b0000000000000000,0b0000111111110000,0b0001111111111000,
0b0011111011111100,0b0011100000111100,0b0000000000111100,
0b0001111111111100,0b0011111111111100,0b0111110000111100,
0b0111100001111100,0b0111110001111100,0b0011111111111100,
0b0001111110011110,
0x0032,
0b0111100000000000,0b0111100000000000,0b0111100000000000,
0b0111100000000000,0b0111101111100000,0b0111111111111000,
0b0111111111111100,0b0111100000011110,0b0111100000011110,
0b0111100000011110,0b0111100000011110,0b0111100000011110,
0b0111100000011110,0b0111111000111100,0b0111111111111100,
0b0111101111110000,
0x0021,
0b0000000000000000,0b0000011111100000,0b0001111111111000,
0b0011111111111100,0b0011110000111110,0b0111100000000000,
0b0011110000011110,0b0011111000111100,0b0001111111111000,
0b0000011111110000
 int16 kk;
 int16 v1_1,v1_2,v1_3,v1_4,v1_5,v1_6;
 int16 v2_1,v2_2,v2_3,v2_4,v2_5,v2_6;
 int16 v3_1,v3_2,v3_3,v3_4,v3_5,v3_6;
 int16 v4_1,v4_2,v4_3,v4_4,v4_5,v4_6;
 int16 v5_1,v5_2,v5_3,v5_4,v5_5,v5_6;
 int16 v6_1,v6_2,v6_3,v6_4,v6_5,v6_6;
 int16 v7_1,v7_2,v7_3,v7_4,v7_5,v7_6;
 int16 v8_1,v8_2,v8_3,v8_4,v8_5,v8_6;
 int16 v9_1,v9_2,v9_3,v9_4,v9_5,v9_6;
 int16 v10_1,v10_2,v10_3,v10_4,v10_5,v10_6;
 int16 v11_1,v11_2,v11_3,v11_4,v11_5,v11_6;
 int16 v12_1,v12_2,v12_3,v12_4,v12_5,v12_6;
 int16 v13_1,v13_2,v13_3,v13_4,v13_5,v13_6;
 int16 v14_1,v14_2,v14_3,v14_4,v14_5,v14_6;
 int16 v15_1,v15_2,v15_3,v15_4,v15_5,v15_6;
 int16 v16_1,v16_2,v16_3,v16_4,v16_5,v16_6;
 int16 val1,val2,val3,val4,val5,val6,val7,val8,val9,val10,val11,val12,val13,val14,val15,val16;
 int16 t_dis[16];
 char joshii;
 int16 joshin;
 int16 rahul;
 unsigned char shij;
 int1 recv,flg;
 #bit SSPIF = 0xf9e.3
 #byte SSPBUF=0xFC9
 #byte STATUS = 0xFD8
 #bit c = STATUS.0
 #int_RDA
RDA_isr()
#int_SSP
void SSP_isr()
   SSPIF = 0;
      switch(kk)
         case 0:
            SSPBUF = ((v16_1 >> 8) & 0x00ff);
            kk++;
         case 1:
            SSPBUF = (v16_1 & 0x00ff) ;
            kk++;
         case 2:
            SSPBUF = ((v16_2 >> 8) & 0x00ff);
            kk++;
         case 3:
            SSPBUF = (v16_2 & 0x00ff);
            kk++;
         case 4:
            SSPBUF = ((v16_3 >> 8) & 0x00ff);
            kk++;
         case 5:
            SSPBUF = (v16_3 & 0x00ff);
            kk++;
         case 6:
            SSPBUF = ((v16_4 >> 8) & 0x00ff);
            kk++;
         case 7:
            SSPBUF = (v16_4 & 0x00ff);
            kk++;
         case 8:
            SSPBUF = ((v16_5 >> 8) & 0x00ff);
            kk++;
         case 9:
            SSPBUF = (v16_5 & 0x00ff);
            kk++;
         case 10:
            SSPBUF = ((v16_6 >> 8) & 0x00ff);
            kk++;
         case 11:
            SSPBUF = (v16_6 & 0x00ff);
            kk++;
         case 12:
            down_send(1);
            output_high(down_cs);
            output_low(down_cs);
            output_high(shift_cs);
            output_low(shift_cs);
            SSPBUF = (v15_1 >> 8) & 0x00ff;
            kk++;
         case 13:
            SSPBUF = (v15_1 & 0x00ff);
            kk++;
         case 14:
            SSPBUF = (v15_2 >> 8) & 0x00ff;
            kk++;
         case 15:
            SSPBUF = v15_2 & 0x00ff;
            kk++;
         case 101:
            SSPBUF = v8_3 & 0x00ff;
            kk++;
         case 102:
            SSPBUF =(v8_4 >> 8) & 0x00ff;
            kk++;
         case 192:
            down_send(0);
            kk=0;
   int16 temp;//delay
   char k,j;//display position
   set_tris_b (0);
   set_tris_c (0b10000000);
   output_low(down_clk);
    kk = 0;
   joshii = 0;
   joshin = 0;
   rahul=0;
   recv = 0;
   shij = 0;
   flg = 1;
   v1_1=v1_2=v1_3=v1_4=v1_5=v1_6=0;
   v2_1=v2_2=v2_3=v2_4=v2_5=v2_6=0;
   v3_1=v3_2=v3_3=v3_4=v3_5=v3_6=0;
   v4_1=v4_2=v4_3=v4_4=v4_5=v4_6=0;
   v5_1=v5_2=v5_3=v5_4=v5_5=v5_6=0;
    v6_1=v6_2=v6_3=v6_4=v6_5=v6_6=0;
    v7_1=v7_2=v7_3=v7_4=v7_5=v7_6=0;
   v8_1=v8_2=v8_3=v8_4=v8_5=v8_6=0;
    v9_1=v9_2=v9_3=v9_4=v9_5=v9_6=0;
    v10_1=v10_2=v10_3=v10_4=v10_5=v10_6=0;
    v11_1=v11_2=v11_3=v11_4=v11_5=v11_6=0;
    v12_1=v12_2=v12_3=v12_4=v12_5=v12_6=0;
    v13_1=v13_2=v13_3=v13_4=v13_5=v13_6=0;
    v14_1=v14_2=v14_3=v14_4=v14_5=v14_6=0;
    v15_1=v15_2=v15_3=v15_4=v15_5=v15_6=0;
    v16_1=v16_2=v16_3=v16_4=v16_5=v16_6=0;
    //setup
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_64);
   //setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_64);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
  // setup_timer_2(T2_DIV_BY_1,5,1);
   setup_timer_2(T2_DISABLED,5,1);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_SSP);
   setup_oscillator(False);
   //end set up
      SSPIF = 1;
   k = 0;
   j = 0;
   for(temp=0;temp<16;temp++)
   t_dis[temp] = 0;
   for(;;)
         val1   = ( t_dis[15]  & and[k] ) << j;
         val2   = ( t_dis[14]  & and[k] ) << j;
         val3   = ( t_dis[13]  & and[k] ) << j;
         val4   = ( t_dis[12]  & and[k] ) << j;
         val5   = ( t_dis[11]  & and[k] ) << j;
         val6   = ( t_dis[10]  & and[k] ) << j;
         val7   = ( t_dis[9]   & and[k] ) << j;
         val8   = ( t_dis[8]   & and[k] ) << j;
         val9   = ( t_dis[7]   & and[k] ) << j;
         val10  = ( t_dis[6]   & and[k] ) << j;
         val11  = ( t_dis[5]   & and[k] ) << j;
         val12  = ( t_dis[4]   & and[k] ) << j;
         val13  = ( t_dis[3]   & and[k] ) << j;
         val14  = ( t_dis[2]   & and[k] ) << j;
         val15  = ( t_dis[1]   & and[k] ) << j;
         val16  = ( t_dis[0]   & and[k] ) << j;
label:
         nxt_char();
         delay_ms(1);
      k++;
      if (k == 16 || k == 17)
         val1=val2=val3=val4=val5=val6=val7=val8=val9=val10=val11=val12=val13=val14=val15=val16= 0;
         goto label;
      j++;
      if(k == 18)
         k = 0;
         j = 0;
         select();
void nxt_char(void)
         v16_5 = modify(val1,v16_5);
         v16_4 = load(v16_5,v16_4);
         v16_3 = load(v16_4,v16_3);
         v16_2 = load(v16_3,v16_2);
         v16_1 = load(v16_2,v16_1);
         v15_5 = modify(val2,v15_5);
         v15_4 = load(v15_5,v15_4);
         v15_3 = load(v15_4,v15_3);
         v15_2 = load(v15_3,v15_2);
         v15_1 = load(v15_2,v15_1);
         v14_5 = modify(val3,v14_5);
         v14_4 = load(v14_5,v14_4);
         v14_3 = load(v14_4,v14_3);
         v14_2 = load(v14_3,v14_2);
         v14_1 = load(v14_2,v14_1);
         v13_5 = modify(val4,v13_5);
         v13_4 = load(v13_5,v13_4);
         v13_3 = load(v13_4,v13_3);
         v13_2 = load(v13_3,v13_2);
         v13_1 = load(v13_2,v13_1);
         v12_5 = modify(val5,v12_5);
         v12_4 = load(v12_5,v12_4);
         v12_3 = load(v12_4,v12_3);
         v12_2 = load(v12_3,v12_2);
         v12_1 = load(v12_2,v12_1);
         v11_5 = modify(val6,v11_5);
         v11_4 = load(v11_5,v11_4);
         v11_3 = load(v11_4,v11_3);
         v11_2 = load(v11_3,v11_2);
         v11_1 = load(v11_2,v11_1);
         v10_5 = modify(val7,v10_5);
         v10_4 = load(v10_5,v10_4);
         v10_3 = load(v10_4,v10_3);
         v10_2 = load(v10_3,v10_2);
         v10_1 = load(v10_2,v10_1);
         v9_5  = modify(val8,v9_5);
         v9_4 = load(v9_5,v9_4);
         v9_3 = load(v9_4,v9_3);
         v9_2 = load(v9_3,v9_2);
         v9_1 = load(v9_2,v9_1);
         v8_5  = modify(val9,v8_5);
         v8_4 = load(v8_5,v8_4);
         v8_3 = load(v8_4,v8_3);
         v8_2 = load(v8_3,v8_2);
         v8_1 = load(v8_2,v8_1);
         v7_5  = modify(val10,v7_5);
         v7_4 = load(v7_5,v7_4);
         v7_3 = load(v7_4,v7_3);
         v7_2 = load(v7_3,v7_2);
         v7_1 = load(v7_2,v7_1);
90% of code deleted.
Reason: Phpbb can not display it.
-- Forum Moderator
