Timer0 question - what should I do?
PostPosted: Thu Feb 18, 2010 11:52 am     Reply with quote
Sad need help plz
Hi, I'm using timer0. I need to show real time elapsed time on lcd.
This is my code...
#include <16F877A.h>
#include <lcd flex driver.c>
int main()
   float dt;
   lcd_init();
   SETUP_TIMER_0(0);
   set_timer0(0);
      dt=get_timer0();
      printf(lcd_putc,"\fX:%3.2f",dt);
   return 0;
Code can be compiled, but when simulated with Proteus, the highest value is only 250++, then it will restart.
I already tried playing with setting here --> set_timer0(0);
but it didn't work.
I want it work as stopwatch.
PostPosted: Thu Feb 18, 2010 12:31 pm     Reply with quote
You are testing it in a loop. When Timer0 counts up to 0xFF, then it rolls
over to start again at 0x00. That's the normal behavior of the timer.
Also, your printf() statement takes a large amount of time to execute.
During that time, many counts of the timer will be skipped. You won't
see them in the display.
CCS has stopwatch examples for Timer0, Timer1, and Timer2.
See these files in the CCS compiler directory:
c:\program files\picc\examples\ex_stwt.c
c:\program files\picc\examples\ex_stwt1.c
c:\program files\picc\examples\ex_stwt2.c
