monsters_inc
CCS 4104 Compiler Bug! |
Posted: Wed Feb 17, 2010 5:25 am |
I use CCS 4104 PCWHD compiler with PIC24FJ256GA106.
When I use directive "#type unsigned" compiler replaces in code destination address of one BRA or CALL instruction with 0x20C wich produces PIC restart.
Function with BRA or CALL instruction with wrong destination address depends of code that I add or remove.
If I compile exact same code with v4093 or v 4099 everything is ok.
If I remove directive "#type unsigned" everything is ok with CCS v4104, but I need by default int8, int16 and int32 to be unsigned.
If I compile in debug mode with CCS v4104 everything is ok.
#include<24FJ256GA106.h>
#type unsigned
#device ADC=10
#define write_SPI(data) spi_write(data); spi_read()
#define read_SPI() spi_read(0)
Compiled code with wrong destination address of BRA instruction - at address 01202h(CCS v4104):
.................... //--- 6 high address bits
.................... write_SPI(Make8(address, 2));
011C2: MOV 2C60,W5
011C4: PUSH 248
011C6: MOV.B W5L,[W15-#2]
011C8: POP 248
011CA: BTSC.B 240.1
011CC: BRA 11CA
011CE: BCLR.B 240.6
011D0: BTSS.B 240.0
011D2: BRA 11D0
011D4: MOV.B 248,W0L
011D6: BCLR.B 240.6
.................... //--- 8 middle address bits
.................... write_SPI(Make8(address, 1));
011D8: PUSH 2C5E
011DA: MOV [--W15],W5
011DC: LSR W5,#8,W5
011DE: PUSH 248
011E0: MOV.B W5L,[W15-#2]
011E2: POP 248
011E4: BTSC.B 240.1
011E6: BRA 11E4
011E8: BCLR.B 240.6
011EA: BTSS.B 240.0
011EC: BRA 11EA
011EE: MOV.B 248,W0L
011F0: BCLR.B 240.6
.................... //--- 8 low address bits
.................... write_SPI(Make8(address, 0));
011F2: MOV 2C5E,W5
011F4: PUSH 248
011F6: MOV.B W5L,[W15-#2]
011F8: POP 248
011FA: BTSC.B 240.1
011FC: BRA 11FA
011FE: BCLR.B 240.6
01200: BTSS.B 240.0
01202: BRA 20C <---- Wrong destination address - 0x20C
01204: MOV.B 248,W0L
01206: BCLR.B 240.6
Compiled code without "#type unsigned" and correct destination address of BRA instruction - at address 01202h (CCS v4104):
011C2: MOV 2C60,W5
011C4: PUSH 248
011C8: POP 248
011CA: BTSC.B 240.1
011CC: BRA 11CA
011CE: BCLR.B 240.6
011D0: BTSS.B 240.0
011D2: BRA 11D0
011D6: BCLR.B 240.6
011D8: PUSH 2C5E
011DC: LSR W5,#8,W5
011DE: PUSH 248
011E2: POP 248
011E4: BTSC.B 240.1
011E6: BRA 11E4
011E8: BCLR.B 240.6
011EA: BTSS.B 240.0
011EC: BRA 11EA
011F0: BCLR.B 240.6
011F2: MOV 2C5E,W5
011F4: PUSH 248
011F8: POP 248
011FA: BTSC.B 240.1
011FC: BRA 20C
011FE: BCLR.B 240.6
01200: BTSS.B 240.0
01202: BRA 1200 <---- Correct destination address
01206: BCLR.B 240.6
Has anyone seen something like this?
sorry for my english |
bkamen
Posted: Wed Feb 17, 2010 7:25 am |
So when you declare your var's, use unsigned in their declaration.
Or make a type like MCHP does in all their code. (uppercase stuff like BYTE and WORD)
or uB or uW or uL
Wayne_
Posted: Wed Feb 17, 2010 8:38 am |
Taken from the help
"Note: All types, except float, by default are unsigned; however, may be preceded by unsigned or signed. "
Notice, all types are unsigned by default anyway! |
Posted: Wed Feb 17, 2010 9:22 am |
This is one of those 'beware of the manual' bits.....
Unsigned, is the default, _unless_ he is running in ANSI mode. The manual has not been updated to reflect this (it is in the 'readme.txt' fo the compiler).
So for every other mode, "#type unsigned", is pointless, but for ANSI mode it is useful. Now 'oddities' with signed values on the latter chips, have been reported here in a number of other threads... :-(
I'd suggest trying in CCS4 mode, and switching the string handling to ANSI if required. Except then for the default integer sizes, this should be close to operating the same.
Posted: Wed Feb 17, 2010 10:17 am |
Hi, Wayne_, Ttelmah, For PCD compiler(PIC24, dSPIC) by default is signed:
Note: All types, except char, by default are signed; however, may be preceded by unsigned or signed (Except int64 may only be signed). Short and long may have the keyword INT following them with no effect. Also see #TYPE to change the default size.
This is from PCD.CHM.
Best Regards. |
Posted: Wed Feb 17, 2010 12:58 pm |
CCS tried to make the data types for the PCD compiler be more like conventional C:
PCD Compiler Reference Manual
C Standard Type Default Type
short int8
char unsigned int8
int int16
long int32
long long int64
float float32
double float64
Note: All types, except char, by default are signed.
Compare that to the C18 data types on page 11:
http://ww1.microchip.com/downloads/en/DeviceDoc/C18_User_Guide_51288j.pdf
The PCD compiler still has some differences, such as a 'short' is 8-bits
and a char is unsigned. That's different from ANSI. |
Posted: Wed Feb 17, 2010 1:59 pm |
The #type preprocessor command has generated unexpected side effects with some previous PCD versions, I stopped
using it since then. The special thing with the present bug is, that it has no reasonable explanation, so it's no clear,
if it generally depends on #type only. In any case, the bug has to be fixed by CCS.
PCD has considerably improved in the last 18 month since I'm using it. In the beginning I found several new bugs
each day. Now it's from time to time. |
monsters_inc
Posted: Wed Feb 17, 2010 2:00 pm |
Hi. I added two more files with code to the project and found that the wrong destination addres of BRA, CALL instructions appear with or without directive "#type unsigned".
This is strange!
Posted: Wed Feb 17, 2010 2:05 pm |
Yes, I feared something like this. You may need to fall back to a previous PCD version, until CCS fixes the bug. I wonder, if there's something special with your application. V4.104 is out since 6 weeks. Someon else should have experienced the problem before. |
monsters_inc
Posted: Wed Feb 17, 2010 2:16 pm |
There is nothing special in project. A lot of code for driving three serial ports, SPI and ADC. The strange thing is that always destination address is 0x20C and only on one BRA or CALL instruction! |
Posted: Wed Feb 17, 2010 3:03 pm |
There seems to be something really attracting at address 0x20C. Perhaps you find out, what it is. |
monsters_inc
Posted: Thu Feb 18, 2010 12:13 am |
Address 20C doesn't exist in listing. |
Posted: Thu Feb 18, 2010 12:35 am |
Quote: | Address 20C doesn't exist in listing. |
The built-in function code starts from 0x200. You have to uncomment the #nolist directive in 24FJ256GA106.h to see it. |
monsters_inc
Posted: Thu Feb 18, 2010 1:12 am |
Thanks for info FvM. I'll try. |
monsters_inc
Posted: Thu Feb 18, 2010 2:03 am |
Hi, 0x200 is start address of function that pass string char by char to printf function and 0x20C is start address of string.
.................... #type unsigned
.................... #include "24FJ256GA106my.h"
.................... //////// Standard Header file for the PIC24FJ256GA106 device ////////////////
.................... #device PIC24FJ256GA106
00200: CLR 32
00202: MOV #20C,W3
00204: ADD W3,W0,W0
00206: TBLRDL.B[W0],W0L
00208: CLR.B 1
0020A: RETURN
0020C: DATA 54,69,00
0020E: DATA 6D,65,00
00210: DATA 20,6E,00
00212: DATA 6F,77,00
00214: DATA 20,69,00
00216: DATA 73,3A,00
00218: DATA 20,00,00
.................... int8 DTF_ReadDevID(int8 dbg)
.................... int8 tmp;
.................... //--- Wait DTF_Ready
.................... tmp = DTF_WaitReady(1, dbg);
00F98: MOV #1,W4
00F9A: MOV W4,18C4
00F9C: MOV.B 18C1,W0L
00F9E: MOV.B W0L,18C3
00FA0: CALL F28
00FA4: MOV.B W0L,18C2
.................... tmp = DTF_ReadDevID(dbg);
01154: MOV.B 18BD,W0L
01156: MOV.B W0L,18C1
01158: CALL 20C <--- wrong desrtination address.
0115C: MOV.B W0L,18BE
.................... printf(dbg_putc, "Time now is: ");
01444: MOV #0,W1
01446: MOV W1,W0
01448: CALL 200
0144C: INC W1,W1
0144E: MOV W1,[W15++]
01450: MOV.B W0L,18D1
01452: CALL E5C
01456: MOV [--W15],W1
01458: MOV #C,W0
0145A: CPSGT W1,W0
0145C: BRA 1446
