angielaz
Using MPLAB with CCS compiler to generate hex file to ECIO40 |
Posted: Wed Jul 01, 2009 5:24 am |
Hi all!
I'm trying to use MPLAB with CCS compiler in order to generate the hex file for the ECIO40P which is a USB product from matrix multimedia. This product has a PIC18F4455.
Does anyone tried something similar?
For now I'm just trying to put a led blinking in port B0.
The code I'm using is:
#include <18F4455.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP
//,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
output_low(PIN_B0);
output_high(PIN_B0);
output_low(PIN_B0);
I'm able to build the project and flash the ECIO... but the behavior is not the one I expected. The ECIO is always plugging in and out of the computer.. the PC is always playing the sound like if I was plugging in and out an USB device.
I'm new using PIC and MPLAB... so I'm out of ideas.
Can you give me some help?
Thanks in advance,
Ângela |
angielaz
Posted: Wed Jul 01, 2009 9:40 am |
ok... is it possible and I found out what was missing.
the usb_booloader.h
Code: | ///////////////////////////////////////////////////////////////////////////
//// USB_BOOTLOADER.H ////
//how big is the bootloader?
//the bootloader will reside from address 0x0000 to this location. the
//application will then sit at this location+1 to the end of program memory.
#define LOADER_SIZE (0xFFF)
#define LOADER_START (0)
#define LOADER_END (LOADER_SIZE)
#define APPLICATION_START (LOADER_SIZE+1)
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-1)
#define APPLICATION_ISR (APPLICATION_START+8)
#ifndef _bootloader
//in the application, this moves the reset and isr vector out of the bootload
//space. it then reserves the loader space from being used by the application.
#build(reset=APPLICATION_START, interrupt=APPLICATION_ISR)
#org 0, LOADER_END {}
and I got the led blinking.
Now I only need to put the PIC communicating by USB and with the PC in execution time.... any good examples?
thanks!!
Regards,
Ângela
Regards,
Ângela |
vhdl Guest
not working |
Posted: Mon Feb 15, 2010 1:28 pm |
do you have other example to compile ecio40 from ccs? |
