Tektronix
ethernet module |
Posted: Sat Feb 13, 2010 3:08 pm |
I am trying to send serial data to a Parallax Internet Netburner embedded Ethernet module. I am using the PCWH compiler version 4.104. The documentation from Parallax shows how to send serial data to the module using a basic stamp. I am trying to use a pic18f452 chip and the PCWH compiler.
Part of my code is:
#include <18F452.h>
#use delay(clock=10000000)
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B0,STREAM=NET,ERRORS,TIMEOUT=20, BRGH1OK )
fprintf (NET,"!NB0W21:TEST");
I do not think that the pins are not switched around because the fprintf statement will work about 60% of the time. |
Posted: Sat Feb 13, 2010 3:31 pm |
You're using a software UART. Are you using interrupt routines in your
program ? If so, when interrupts occur, they will disrupt the bit timing of
the software UART. You can prevent that by adding the DISABLE_INTS
parameter to your #use rs232() statement. From the manual:
Quote: |
#USE RS232
DISABLE_INTS -
Will cause interrupts to be disabled when the routines get or put a
character. This prevents character distortionfor software implemented
I/O and prevents interaction between I/O in interrupt handlers and the
main program when using the UART.
Also, on a software UART, the parameters shown in bold don't do anything.
The compiler ignores them. |
Tektronix
Posted: Sat Feb 13, 2010 4:20 pm |
That was very good information. I wished the manual was a little clearer on which options are for software UART and which are for the hardware UART. I am still having trouble with the Ethernet module. The data is still not showing up. It might be a problem with the Netburner Ethernet module. Thanks again. |
jaimechacoff
Joined: 14 Feb 2010 Posts: 24 Location: Santiago, Chile
Posted: Sun Feb 14, 2010 12:14 pm |
hey, I think your problem with the Netburner is because you are connecting it through a router and because that now you cant see the information.
I know this because I have used the Netburner, and I had the same problem and it was just because the Netburner doesnt work under a router.
good luck. |
Tektronix
Posted: Sun Feb 14, 2010 5:42 pm |
It’s possible that the netburner does not work well with a router, but not sure. I had the netburner module hooked up using a basic stamp which worked very well. I used the examples from the Parallax web site. Does anyone know an example in which serial data is sent or received from a PIC chip to a basic stamp? The basic stamp commands can send and receive serial data with a delay (pace) option. I am not sure how much delay is actually between characters being sent. What is the best way to send a null character through the serial port?
I have modified the code for the PIC18F452 chips many times and then tested, but still no luck.
Code: | #include <18F452.h>
#define CLS 0
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B0,stream=net,errors,timeout=20,disable_ints )
void main
fprintf (net," !NB0W04:WORKS OK \0");
fprintf (net," !NB0W04:WORKING OK%s",CLS);
while(TRUE){
fprintf (net," !NB0W04:Test");
jaimechacoff
Tektronix
Posted: Mon Feb 15, 2010 7:30 pm |
The netburner displays the web pages just fine with the router setup I have. I just trouble getting the PIC18F452 to update variables on the displayed web pages. The same netburner with a basic stamp does update the variables as expected with basic code. |
