speed ramp
j_andres
speed ramp
PostPosted: Fri Feb 12, 2010 4:36 pm     Reply with quote
Anyone has a code for a speed ramp, or some explanation about how to implement it.
Thanks.
PostPosted: Fri Feb 12, 2010 5:47 pm     Reply with quote
Speed ramp for what ? PWM ? Stepper Motor ?
If you want help, you need to give more details. We are not mindreaders.
j_andres
yes yes, PWM
PostPosted: Sat Feb 13, 2010 5:55 am     Reply with quote
sorry PCM Programmer, you are right, and yes, I need one for PWM.
what i cant understand is how to set the time between increasing, constant and decreasing speed, in a "X" time between A and B position of the servo motor.
thanks
j_andres
PostPosted: Sat Feb 13, 2010 6:18 am     Reply with quote
by the way,
I have also an encoder, now i am implementing a PID controller and the ramp, until now, i read very well the encoder and i have implemented a P controller, but still my movement are too heavy, and before to implement the I controller i would like to have the ramp ...
j_andres
PostPosted: Sat Feb 13, 2010 7:22 am     Reply with quote
and this is my own "ramp"
int16 reference=554;      // actually the steps i want to move the motor
int16 referenc2=0;
int16 duty=0;              // PWM
int16 i=1;                 // actually the encoder counts
      while (i<=reference/4){             // increasing speed
         duty+=2;
            if (duty>=121) duty = 121;    // max speed
         printf("\fDuty = %ld\n\ri = %ld",duty,i);
         delay_ms(50);
      i++;
      referenc2 = 3 * reference;
      referenc2 /= 4;
      for(i;i<=referenc2;++i){
         duty = duty;
         delay_ms(50);
      while (i>=referenc2){            // decreasing speed
         if (i == reference+1){
            duty = 0;
         else{
            duty-=2;
               if (duty < 0){
                  duty = 0; // min speed
         delay_ms(50);
      i++;
} // end main
I am fixing how to get 0 duty when the i count reach the reference ....
PostPosted: Sat Feb 13, 2010 12:30 pm     Reply with quote
Here is a routine which changes the PWM duty cycle in the #int_Timer2
interrupt:
http://www.ccsinfo.com/forum/viewtopic.php?t=41473&start=3
j_andres
PostPosted: Sat Feb 13, 2010 2:34 pm     Reply with quote
Thank you.
It was useful : )
Please, is there any technic to calculate the speed of the motor with the encoder?
I am trying to read the encoder with a certain time and then say that "n counts" by ticks is my speed ...
