Oli Guest
manually changing oscillator source on PIC24 [how-to] |
Posted: Fri Feb 12, 2010 5:33 am |
I needed to change the clock source and found the setup_oscillator function inadequate, especially if switching from a non-PLL mode to PLL mode. There is an unlocking sequence that must be followed first and executed in assembly.
The code below changes the NOSC 2:1 bits to 011 to select the oscillator source as primary, with PLL enabled.
Code: | #asm
//;Place the new oscillator selection in W0
MOV.b #0x03, w0 // NOSC2:0 = 011 - primary osc with PLL
//;OSCCONH (high byte) Unlock Sequence
MOV #0x0743,w1
MOV #0x78, w2
MOV #0x9A, w3
//DISI #0x5 // uncomment if you have interrupts enabled
MOV.b w2, [w1]
MOV.b w3, [w1]
//;Set new oscillator selection
MOV.b w0, [w1]
mov #0x01, w0 // clock switching enabled
//;OSCCONL (low byte) unlock sequence
MOV #0x0742,w1
MOV #0x46, w2
MOV #0x57, w3
MOV.b w2, [w1]
MOV.b w3, [w1]
//;Start oscillator switch operation
MOV.b w0, [w1]
#endasm |
EDIT: The values 0x0742 and 0x0742 are the addresses for the OSCCON high and low bytes on the PIC24FJ256GB110
Posted: Fri Feb 12, 2010 7:27 am |
Yes, curiously CCS PCD is using a non-operational unlocking sequence in some places. The below code (used in PCD #PIN_SELECT code) does not work, because W0 is loaded between both writes to the unlock register. In this case, the pin select register shall be proteceted, but they aren't.
Code: | 00334: MOV #46,W0
00336: MOV.B W0L,742
00338: MOV #57,W0
0033A: MOV.B W0L,742
0033C: BSET.B 742.6 |
