russk2txb
I2C Problems |
Posted: Thu Feb 11, 2010 10:04 am |
Hi. I'm having a problem with using the 18F6723 as an I2C slave. Here is the relevant code:
#use i2c (slave, sda=PIN_C4, scl=PIN_C3, address=0xA0, FORCE_HW, stream=IC_PHASE)
#INT_SSP
void I2C_PhaseInterrupt ()
int state;
state = i2c_isr_state (IC_PHASE);
if (state < 0x80) // Master is sending data
bPhaseChange = true;
else // Master is requesting data from slave
i2c_write (IC_PHASE, 0); // master should never request data
// but send something if it does...
Then in the main loop when the flag is found to be set:
int word [3];
SINT i = 0;
long t;
for (t=0; t < 10000; ++t) {
if (i2c_poll (IC_PHASE)) {
word [i] = i2c_read (IC_PHASE);
++i;
if (i > 2) // expecting 3 bytes
First, I don't always get an interrupt when I send the data. Sometimes the interrupt is every other time, other times I can have to send data several times before I get the interrupt. I can make no sense of this.
Second, when I do get an interrupt, very often the first i2c_poll returns true, as expected, but then hangs forever when i2c_read is called.
Sometimes I get only one byte, and very rarely all three. I do have pullups on the I2C lines, and in addition the data I do get is always correct, so I don't think it is a hardware problem on the bus.
I am sending the data via a USB to I2C device called "USB to I2C Pro", made by a company called I2C Tools. The API call I am using is called I2CWriteByte, and it expects the address, a sub address, and a data byte. I expected to only receive two bytes, the sub address and data bytes, but it turns out that (when it works) I get 3 bytes, the address, the sub address, and the data byte.
Is it normal that I would actually receive the address value? I thought the I2C interrupt on address match would consume the address value and only deliver subsequent data bytes?
Can anyone shed any light on why the i2c_poll function returns true but then there is no data, or why there would be no data in the first place once an interrupt is received???
Thanks, Russ |
Posted: Thu Feb 11, 2010 3:30 pm |
As for 'why', to start the transaction, the master must send the slave address (you don't show this). The slave then interrupts, with the address byte _waiting to be read_. You are not reading this byte. This then leaves the slave in an invalid state. Basically, like any device dealing with hardware, you _must_ perform the expected service for the data being handled. If you look at the CCS example, you will see that it reads the address byte, allowing the code to progress to the next stage.
russk2txb
I2C Problems |
Posted: Thu Feb 11, 2010 6:51 pm |
Ttelmah, thanks. I don't show the master code because it is not in a PIC. It is sent from a PC through the USB to I2C converter. But it is obvious that the address is being sent, else I would not get an interrupt.
Also, I am reading the address byte. I am reading 3 bytes. The only thing I am doing different is to do the actual reads outside of the interrupt handler. Interrupt handlers should be fast, so I just set a flag and then do the actual reading when the main program loop detects the flag.
My question was why the address was there to be read. I can see no reason for it, since we already know what address was received - else we would not have gotten the interrupt. So I did not expect this. All I really wanted was confirmation that the address byte is expected.
Also the example code does not indicate that the byte being read (in the interrupt handler) is the address. So I thought it was reading a data byte.
None of this explains why the program hangs trying to do i2c_read, after getting a true return from i2c_poll.
Tomorrow I am going to get a good storage scope hooked up on the bus so I can see exactly what is being sent. That may give me some clues.
Thanks again, Russ |
