Place a const at a fixed location? |
Posted: Wed Feb 10, 2010 8:12 am |
I want to place this line at fixed location in the code, how to do that?
Code: | Const char IDNr[] = {"hw:2.00 / fw:1.20"}; |
hints? |
Wayne_
Posted: Wed Feb 10, 2010 10:52 am |
Look at #org in the help. |
languer
Posted: Wed Feb 10, 2010 2:13 pm |
I've used something similar to the code shown in this post.
The location is usually the last implemented registers.
Example for 12F629:
Code: | #ORG 0x3D0,0x3DF
const char build_rev[] = {"Rev 1.0"}; // max length = 15
#ORG 0x3E0,0x3EF
const char build_date[] = __DATE__; // max length = 15
#ORG 0x3F0,0x3FF
const char build_time[] = __TIME__; // max length = 15
printf("%s\nBuild: \%s, \%s\n\r", build_rev, build_date, build_time);
Posted: Wed Feb 10, 2010 2:45 pm |
I dont understand I cant compile it when using the #ORG xx yy statement?
I get error...
I place the statement at the top of my main.c file. |
Posted: Wed Feb 10, 2010 3:51 pm |
Thanks, But wont work.
I use:
Code: | #org 0x300, 0x310
Const Char IDNr[] = "v1.0"; |
And get this error:
Code: | *** Error 71 "main.c" Line 444(0,1): Out of ROM, A segment or the program is too large @const76
Seg 00300-00310, 0012 left, need 0022
Its the same error even if I change the #org addr space? |
Posted: Wed Feb 10, 2010 3:54 pm |
Post your PIC and your compiler version. |
languer
Posted: Wed Feb 10, 2010 6:22 pm |
Also post the small program...
I believe this:
Code: | Const Char IDNr[] = "v1.0"; |
should read:
Code: | Const Char IDNr[] = {"v1.0"}; |
Your address looks pretty low too:
Normally you would place this at the top range of the code space. |
