PRINTF an int32 with decimal points (faking a float value)
ELCouz
PostPosted: Sun Feb 07, 2010 11:07 pm     Reply with quote
Is it possible to have %w formatting but with an int32 integer?
Example value of 999999 to be displayed like %4.2w (9999.99).
Passing an int32 with %w give me garbage prints on my lcd.
Have a nice day!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Mon Feb 08, 2010 12:49 am     Reply with quote
You didn't specify your PIC or your version. So, I ran the following test
program with vs. 4.104 and a 14F452. MPLAB simulator gives me the
following result:
9999.99
#include <18F452.h>
int32 value;
value = 999999;
printf("%4.2w", value);
ELCouz
PostPosted: Mon Feb 08, 2010 4:39 pm     Reply with quote
PCWHD 1.104 with dspic30f4013.
Your code return me a lot of garbage chars.
In fact I've tested with an uint8 same thing! (I don't know if it's a problem with PCD, i can't test with a anything else i'm out of PIC except dspics)
What could be the other alternative for inserting a dot when displaying value.
It's just a matter of putting the decimal at the right place.
I think if it's possible to read the int32 and on the last field insert a dot in between (from 99999 example value) this would result in 9999.9 being displayed
Thank you very much for you help Smile
EDIT: i thought dividing 10 the value but this would require to have a float variable which i would like to avoid if possible ?
Regards,
Laurent
PostPosted: Mon Feb 08, 2010 5:06 pm     Reply with quote
I can't test with anything else.
You can test other PICs in the MPLAB Simulator, using the "UART1"
feature (of MPLAB) to display text in the Output Window:
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
ELCouz
PostPosted: Mon Feb 08, 2010 7:04 pm     Reply with quote
Your code run well in MPLAB SIM
but this doesn't:
#include <30f4013.h>
#FUSES FRC_PLL16,PR_PLL,NOWDT,NOPUT,NOMCLR,NOBROWNOUT
#use delay(clock=117920000)
int32 value;
value = 999999;
it crash during execution (but compiling is successful) and SIM UART1 Tab is empty no output from serial
hmmm i don't have any clue why it doesn't work even with simulation
thanks!
Regards,
Laurent
PostPosted: Tue Feb 09, 2010 2:24 am     Reply with quote
You could do a work-around for the %w format, by using using division
and the modulo operator to calculate the quotient and the remainder.
Then just display the quotient and the remainder in one printf statement,
with a '.' between the format specifiers for each one.
But first, you need to see how the PCD compiler handles the sign of
the result of the modulo (%) operator. In PCH, the result is always
positive. But CCS may follow a different standard (C99 ?) in PCD.
Change the program below for the 30f4013 and see what you get
for the remainder. Is it a negative or a positive number ?
#include <18F452.h>
signed int32 dividend;
signed int32 remainder;
signed int32 quotient;
//dividend = 999999;
dividend = -123456;
quotient = dividend / 100;
remainder = dividend % 100;
printf("quotient = %ld\r", quotient);
printf("remainder = %ld\r", remainder);
ELCouz
PostPosted: Wed Feb 10, 2010 7:33 pm     Reply with quote
Dear PCM programmer,
Sorry for the late reply, here's the output of your code from the dspic.
quotient = -1234
remainder = 56
Nice quick fix Smile
I know it's not the best way (I've never use so much dirty workaround in programming ) to do it but it works !
If only PCD was less buggy and more mature like his brothers PCB,PCH and PCM
Best wishes
Regards,
Laurent
