Address of EEPROM ?
jgschmidt
Address of EEPROM ?
PostPosted: Sun Feb 07, 2010 4:48 pm     Reply with quote
I was trying to find the EEPROM address for the #ROM directive on the 12F683. I could not find this on the Microchip datasheet and had to browse forum postings for an example.
Does anyone know where I can find this information in the formal docs? Perhaps I've missed it somewhere but careful perusing of the EEPROM section (10.0) only says EEPROM address locations are numbered from 0x00 to 0xff. However for the #ROM directive the first address location is 0x2100., which was verified by actual test.
Thanks.
PostPosted: Sun Feb 07, 2010 5:00 pm     Reply with quote
This post tells how to find the eeprom address on the Microchip website:
http://www.ccsinfo.com/forum/viewtopic.php?t=35539&start=3
jgschmidt
EEPROM address information not found
PostPosted: Sun Feb 07, 2010 9:57 pm     Reply with quote
Thanks for the quick reply. However, the document referenced in the post does not have a section 5.5 and references the memory locations EXCEPT EEPROM. The document has been updated since that post.
PostPosted: Mon Feb 08, 2010 12:36 am     Reply with quote
Here's the latest Programming Specification for the 12F683.
http://ww1.microchip.com/downloads/en/DeviceDoc/41204H.pdf
It might not be the exact same section number in every Programming
Specification, but it will be somewhere near end of the document.
In the case of the 12F683, the section is:
5.3.2 Embedding Data Memory Contents in Hex File.
Look at the bottom of page 34.
It does give the address of 0x2100. However, calling it "Data Memory"
instead of "Data EEprom" is confusing.
jgschmidt
PostPosted: Mon Feb 08, 2010 1:35 am     Reply with quote
Thanks! I appreciate you tracking that down. That was well hidden. At least I'll know what to look for when I work with other processors.
