18f97j60 3v and rs232 5v
madhu
PostPosted: Sat Feb 06, 2010 12:55 am     Reply with quote
Dar friends,
My hardware is PIC18f97j60 with 3.3v and rs232 with 5v supply whether it works or not. Please help me.
arunb
re:
PostPosted: Sat Feb 06, 2010 1:43 am     Reply with quote
how is the voltage translation done, between 3.3 V to 5 V and vice-versa ??
thanks
arunb
madhu
PostPosted: Sat Feb 06, 2010 2:22 am     Reply with quote
hi,
u mean it should be either 5V or 3.3V supply voltage for both.
bkamen
PostPosted: Sat Feb 06, 2010 10:03 am     Reply with quote
why not use a 3.3volt capable rs232 interface IC like the MAX3232?
-Ben
asmallri
Re: 18f97j60 3v and rs232 5v
PostPosted: Sat Feb 06, 2010 10:20 am     Reply with quote
madhu wrote:
Dar friends,
It will work but as already suggest, a 3.3V RS232 converter would be a better fit electrically between the PIC and the transceiver however a +5V RS232 would provide a better solution for RS232 because of the high signal level and therefore better signal to noise ratio.
Regards, Andrew
bkamen
PostPosted: Sat Feb 06, 2010 10:47 am     Reply with quote
huh??
The max3232 still puts out about 10V on the RS232 side running at 3.3 or 5.
asmallri
PostPosted: Sun Feb 07, 2010 9:31 pm     Reply with quote
bkamen wrote:
huh??
Not on the test boards I have.
Regards, Andrew
bkamen
PostPosted: Sun Feb 07, 2010 9:36 pm     Reply with quote
asmallri wrote:
bkamen wrote:
huh??
Funky. The spec reads +/-5 5 for a 10V swing.
Good to know.
Those spec sheets... they LIE... ;)
-Ben
