jventerprises
Compiler Status window won't go away! |
Posted: Fri Feb 05, 2010 3:04 pm |
hi,
Anybody else having this problem?..
When I have the IDE up and I alt-tab between different Windows applications, sometimes the compiler status window (the box that shows you stats while compiling) pops up and won't close no matter what I do. The only way to close it is to recompile the source code and then it goes away. Alt-tab will bring it back again.
I have this going on on a Windows XP machine and a Windows Vista machine...
thanks _________________ Jon |
logical
Joined: 21 Dec 2009 Posts: 57 Location: SouthPort, UK
Re: Compiler Status window won't go away! |
Posted: Fri Feb 05, 2010 4:07 pm |
jventerprises wrote: | hi,
thanks
Same here matey, Vista X64.
Do exactly the same, recompile again then it vanishes, have tried to sort it before, running 4.093, one of my colleagues has 4.104, guess what, exactly the same problem.
Chris |
