What do you think this packet handler?
ELCouz
PostPosted: Wed Feb 03, 2010 8:49 pm     Reply with quote
Dear programmers,
I'm working on a PIC to PIC communication (5 packets / sec)
I'm pretty new with Serial comms with interrupts is that short enough or i can improve something?
I figured out that safest way is to need an external «flowcontrol» such a pin rise when packet start. In software only the problem even with a fixed width packet and 2 delimiters you can have an offset if data goes corrupt or contain values that are the same as delimiters
dspic receiver code:
//---PACKET RS232 RX-------
//PACKET = [83,SPEED,WHEEL_0,WHEEL_1,WHEEL_2,WHEEL_3,RPM_0,RPM_1,CHECKSUM]
//BUFFER[0] start with speed and end with CHECKSUM
#INT_RDA
void analyzepacket_isr(){
byte inputchar;
if ((charcount > 7)&&(buffer[7] == buffer[0]+buffer[1]+buffer[2]+buffer[3]+buffer[4]+buffer[5]+buffer[6])) {bufferready = 1;startbuffering =0;} //set the ready flag if checksum pass and buffering done!
inputchar = getc();
//capture the 8 bytes wide data packet
if ((charcount < 7) && (startbuffering == 1)) {buffer[charcount] = inputchar;charcount++;}
//verify if FlowControl is high and the packet is 83 then start buffering data
if ((inputchar == 83) && (input(FlowControl)) && (bufferready == 0)) {charcount = 0;startbuffering =1;}
the emitter code 18f2550
#int_timer3
void timer3_isr(void)
byte checksum;
byte wheel_0,wheel_1,wheel_2,wheel_3;
byte rpm_0,rpm_1;
if (timercount < 4){timercount++} //software postscaler
   else {
   wheel_0 = make8(wheelcount, 0);
   wheel_1 = make8(wheelcount, 1);
   wheel_2 = make8(wheelcount, 2);
   wheel_3 = make8(wheelcount, 3);
   rpm_0 = make8(rpm, 0);
   rpm_1 = make8(rpm, 1);
   checksum = speed + wheel_0 + wheel_1 + wheel_2 + wheel_3 + rpm_0 + rpm_1;
   output_high(pin_a0);
   putc(83); //PACKET START
   output_low(pin_a0);
   putc(speed);
   putc(wheel_0);
   putc(wheel_1);
   putc(wheel_2);
   putc(wheel_3);
   putc(rpm_0);
   putc(rpm_1);
   putc(checksum);
   timercount = 0;
Thank you!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
asmallri
PostPosted: Wed Feb 03, 2010 11:31 pm     Reply with quote
The timer interrupt handler is a problem. The timer interrupt handler will not exit until it has sent all the serial characters out of the interface.
Instead of doing this, use the timer interrupt handler to acquire the data into the respective volatile variables. The set a "data_ready" flag;
In the mainline look for data_ready. If set then, disable the timer interrupt, copy to data the another set of variables (shadow copies if you like) not shared with the timer interrupt handler, reenable the timer interrupt and then printout the contents of these shadow variable. This approach will have minimal impact on the interrupt handler and the data printed will alway be from a complete read of all the variables (i.e. they will not change mid stream as a result of another timer interrupt ocuring).
Regards, Andrew
ELCouz
PostPosted: Thu Feb 04, 2010 4:52 pm     Reply with quote
Thank you for you reply
If i understood you .... you mean this ?
PIC emitter code
TIMER3:
#int_timer3
if (timercount < 3)&&(dataready==0)){timercount++;}
   else {
   dataready = 1;
   timercount = 0;}
and now in the main loop:
// *** PACKET TRANSMIT ***
   if (dataready){
   disable_interrupts(INT_TIMER3);
   buffer[0] = speed;
   buffer[1] = wheel_0;
   buffer[2] = wheel_1;
   buffer[3] = wheel_2;
   buffer[4] = wheel_3;
   buffer[5] = rpm_0;
   buffer[6] = rpm_1;
   buffer[7] = checksum;
   dataready = 0;
   enable_interrupts(INT_TIMER3);
   output_high(PIN_A0);
   putc(83);
   output_low(PIN_A0);
   putc(buffer[0]);
   putc(buffer[1]);
   putc(buffer[2]);
   putc(buffer[3]);
   putc(buffer[4]);
   putc(buffer[5]);
   putc(buffer[6]);
   putc(buffer[7]);
Code could be shorter but I didn't use any loops for the sake of code performance.
Is that what you mean ?
Have a nice day!
Regards,
Laurent
bkamen
PostPosted: Fri Feb 05, 2010 7:48 am     Reply with quote
I agree with Andrew. Your timer3 is unneeded and potentially troublesome.
I do it a little different than he suggests (just a little though).
my INT_RDA is a state machine that:
1:Looks for start of packet
2:collects data to end of packet or buffer (DON'T OVERRUN!)
3:Sets have_packet flag
4:waits for have_packet to be reset by main() routine.
In main:
if have_packet == true, then process it:
1. Copy the packet to a temp buffer
2. clear have_packet (now the INT_RDA can run again)
3. Process packet
The reason I don't DISABLE the interrupt is to allow the flow of inbound chars to keep coming. This way there isn't a buffer overflow.
Yes, I might miss packets, but if I overflow, I miss packets anyway. the ISR is written to ALWAYS getc(); -- but the state machine controls whether that received char is actually saved or discarded.
Cheers,
- Ben
asmallri
PostPosted: Fri Feb 05, 2010 10:41 am     Reply with quote
PIC emitter code
TIMER3:
#int_timer3
   else {
   dataready = 1;
   timercount = 0;}
   if (dataready){
   buffer[0] = speed;
   buffer[5] = rpm_0;
   buffer[6] = rpm_1;
   dataready = 0;
   putc(83);
   output_low(PIN_A0);
   putc(buffer[0]);
   putc(buffer[1]);
   putc(buffer[2]);
   putc(buffer[3]);
   putc(buffer[4]);
   putc(buffer[5]);
   putc(buffer[6]);
   putc(buffer[7]);
Have a nice day!
Yes.
Regards, Andrew
ELCouz
PostPosted: Fri Feb 05, 2010 3:51 pm     Reply with quote
Actually i only use timer to regulate the quantity of data packets that is sent throught the link on the pic that send data (it's a one way communication) and with a timer interrupt i know that packet will not be missed , always on time and priority over the main program.
I also do this anyway you need to getc in the RDA interrupt to clear it (unless you clear it manually) and you may get into trouble if the buffer overflow. Better play safe Smile
Thank you guys for your guidelines Very Happy
Have a nice week-end
Regards,
Laurent
