sizeof(const char *) and sizeof(rom char*)
Danny
PostPosted: Fri Feb 05, 2010 7:50 am     Reply with quote
int32 i;
i=sizeof(const char *) and
i=sizeof(rom char*)
My compiler has a problem evaluating these statements. It complains with the following message
A numeric expression must appear here. Please help
Re: sizeof(const char *) and sizeof(rom char*)
PostPosted: Fri Feb 05, 2010 7:59 am     Reply with quote
Danny wrote:
int32 i;
i=sizeof(const char *);
i=sizeof(rom char*);
Just added semicolon to make things clear in the above. The compiler is version 4 PCH.
Danny
PostPosted: Fri Feb 05, 2010 1:07 pm     Reply with quote
Anyone with an answer?
PostPosted: Fri Feb 05, 2010 2:21 pm     Reply with quote
Always give your full compiler version. See how many versions there are ?
http://www.ccsinfo.com/devices.php?page=versioninfo
Each one of those probably has several other things fixed besides what's
listed.
Always post your PIC. There must be hundreds of PICs. Each one is
different in silicon and in the compiler.
int32 i;
i=sizeof(rom char*)
Do we know that any of this works ? Here is CCS's announcement of
a feature regarding 'const' and pointers.
http://www.ccsinfo.com/content.php?page=compiler-features#pconst
But if I take their sample code and drop it into a test program such
as the one below, and compile it with vs. 4.104, what do I get ?
I get 13 error messages. So I repeat, do we know that any of these
new features work ? You wanted an answer. Well...
Only the features that you can test and prove as working, are the ones
that really work.
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
const char version[] = "PRODUCT ID V1.01";
const char *ptr;
ptr = &version[0];
